Brute force might burst the mounting points. Unbolt one strut at one end and try to close the box. Refit the strut and do the same for the other side. This will tell you if it is one or both struts causing the problem.
They aren't very expensive and there are plenty of websites where you can get replacements. Check the struts for serial numbers, you might even be able to replace them just based on their measured length.
this depends on how password protected it is. i can advise connecting it to your computer and reformatting it as the first course of action.
if this fails you need a brute force hacking program.
The required serial number for SD-Jukebox installation is located on the paper insert inside the CD-ROM casing. The serial number is 10 or 11 digits long depending on the model. Without the serial number, the Jukebox software cannot be installed on a compatible PC.
