Go to this link and download the motherboard manual. It will show what header pins on the board attach to your various panel connections. ECS Web Site 945GCT M3 V3 0
It is normally onto a jumper labelled sw - You dont mention the motherboard type, or if you have the instructions. I would suggest looking very carefully on the printing on the board near a bank of upright pins for "sw". It does not matter which way round you put the switch connector.
If you still cant find it, google foe the instructions for your MB
its simple, start from left power led next to power led is power switch, just below power switch put hdd and next to hdd put reset . thats it done.. all boards have the same module.....
ok man on this picture in the bottom of the pic there will be a sort of black rectangle with nine pins, 5 on bottom, four on top. This is where all your POWER SW,RESET SW,HDD LED,POWER LED will be plugged in. I could not find instructions for your board but for mine it is
Looking at the pins from the side where there are 5 pins on the bottom and 4 on top. The top two sould be the power led the two next to that should be the power switch, the bottom two to the left should be the hard drive led and the two next to that should be reset.
This is not the guaranteed position seeing as we have two completely different models.
for connecting these sw
just see on mother board there you see nearabout 16 pins on right hand bottem of mother board
there you have an integation of connectorfrom right hand corner i.e 1-3 for reset sw, 2-4 for power sw and last switches for front usb and audio
if you have p-3 then you dont attech audio and usb cables on *********** board
what type of motherboard do have? It sud be on right hand-side you will find some pins. USE MEGNIFYING GLASS THERE BE WRITTEN IN SMALL PRINT connect power LED, HDD LED, RESET SW AND POWER SW
