I understand that the yamaha 30 detol outboard has electric tilt/trim and was wondering if the tilt/trim could be fitted to my outboard?
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
SOURCE: my tilt/trim on 1989 force 85hp outboard does not
It sounds like you need to bleed your trim lines. It is a pretty easy task and if that doesnt work you might need to rebuild your trim cylinder. I would bet on bleeding the system first.
SOURCE: how to service a tilt/trim on a 50 hp yamaha
To check the fluid level, tilt the motor up and engage the tilt lock lever. Open the bolt on top of the tilt/trim reservoir. The fluid should be even with the bottom of the bolt hole. If not add some fluid. When you put the bolt back in, run the trim up and down a few times. That should purge any air out of the system. Always be on the lookout for any leaking hoses or fittings. Hope this helped and best wishes.
SOURCE: suzuki outboard DT 140 tilt trim switch worked
Check all wire connections, Check switches at binical and at pan on engine. Bill
SOURCE: want to replace the trim/tilt motors on my 1995
no. a unmodified transom bracket may need to be moved not removed. Since the tilt motor is out you will need to manually lift the engine. you can see the picture diagram at www.yamaha-motor.com. click on outboard motors,parts and service, view parts catalog. find your year make and model by following steps listed at top. select power trim and tilt assembly. in the picture you will see the location of the Manuel release valve on the starboard side. turn the Manuel release valve then lift the engine. tie it up or use a stand to keep it up,do not use the tilt lock. with the engine in full tilt position, you can see the motor. some brackets are modified were you can remove the motor without moving the transom bracket. If unmodified you'll need to follow these steps. (1) lower the engine back down.the steering arm needs to be removed from the steering cable and swung forward. do not remove steering arm from engine. on the starboard side of the engine you will see the steering cable going into the steering cable tube. (2)a 1 1/6 nut secures the cable to that tube remove it and slide cable out do not remove it.(3) lift engine again and secure it. your about to remove the motor mount bolt so make sure you secure the motor completely (4)remove upper and lower transom to bracket bolts remove bolts on the port side only.(5) you will see three bolt that go through the transom bracket to the trim and tilt assembly. remove them.(6) if all bolts are removed you will be able to slide the port transom bracket to the left out of the way(7) remove tilt/trim motor.
