Epson Stylus CX6400 All-In-One InkJet Printer Logo
Posted on May 22, 2017
Physically cleaning printheads on a epson 6400 printer
I should have worded the problem differently. I have already done all of the cleaning procedures that the printer can do. I am sure the ink has dried up since the printer sat awhile I am sure. I am asking what ingredients make up print head cleaner, I really dont want to spend money online if I can make it myself. I have cleaned epsons before using a syringe, alcohol and air to clean out the small holes in the print heads. I am just asking if there is a better way to physically clean them. thanks.
5 Related Answers
Anonymous
  • 29 Answers
  • Posted on Sep 09, 2007
SOURCE: Cleaning the heads on a Epson Photo R300
Unfortunately, the printhead can only be removed by disassembling the printer and paying for the parts if defective. It is just not worth it. If you have already tried new inks (just replace one - not all) and this number of cleaning cycles - there is nothing else. At this point replacing may be the best solution if you are out of the one-year warranty period.
Anonymous
  • 84 Answers
  • Posted on Jan 15, 2008
SOURCE: Removing and cleaning Epson Printheads
I don't know how to remove the print head but if you want to clean it - check for mr.musculo solution from any market near you. Leave the print head in this solution (warmed at about 35 celsius) for several up to 24 hours.
gremlin11
gremlin11
  • 78 Answers
  • Posted on Dec 13, 2008
SOURCE: Cleaning Printhead on a Epson RX650 Printer
Truely, this is a job best left to the professionals. I have been doing these for a few years now and I can tell you that it is fiddly and tricky. The best solution for cleaning a printhead is through software. This is how the professionals do it and it is the only successful method. Removing the printhead in these unit is only ever done when they are replaced and this is not something that can be done without the epson service software as there is a printhead number that must be entered into the eprom to make the head work.
If cleaning of the head through the soft ware has failed, try moving the head to the left of the unit. where the head parks is the ink system assembly, also known as the purge unit. Make yourself a solution of dishwashing liquid and water, about 70% water. Fill the small pad area that the head sits on to almost over flowing and move the head across to park position. Leave the printer for 24 hours and then conduct the deep clean from your software. If you are still unable to clear the heads, than the head is faulty and will need to be replaced. Again, there is codes to enter through service software that is unavailable to all except registered epson warranty service centres, so it will be something to be done by the professionals.
I hope this is helpfull.
Gremlin11
Nandakishore
NANDAKISHORE
  • 304 Answers
  • Posted on Mar 06, 2009
SOURCE: Epson Stylus C88 won't print black ink
You have tried almost all the steps. You have to consult Epson Service Support. Don't try more the head can damage.
Anonymous
  • Posted on Oct 23, 2009
SOURCE: Despite print head and nozzle cleaning, and a new
In desperation tried another new cartridge and it worked perfectly first time: I suspect the first was faulty so off to retailer for refund ASAP. At 30+GBP they dont come cheap!
Testimonial: "Good solution: but are you sure you replaced the right cartridge first time around? "
My printerhead is clogged
You will have to be careful and precise.
Using a needle or other suction product.
Extract some ammonia int it.
Let the printer move the head to center.
Unplug unit.
Take syringe and place a few drops into where the cartridge hole would have lined up
Be carefull not to OVERFILL head.
Install cartridges and let printer sit for an hour or so.
Power back on and let the machine do a self clean.Should be good to go.
EPSON STYLUS PRO 7600 Leaking ink One of my
sir the printer head of your printer is already thin... try to change the printer head...
3answers
New ink not working three different times buying it and taking back ink very light or none at all no red it shows up yellow?
Have you done the cleaning the printhead? if not please run your clean printhead, if your using 5100 printer you can only do clean printhead by launching your home center, just click the help icon(?) under that click maintenance for you to able to see clean printhead
Now if you already done with this torubleshooting and still you haved incomplete color or incorrect colors printouts it means you printhead is defective., YOu need to call kodak tech support for printhead replacement i think its free of charged 1 800 421 6699 ext 05 toll free
3answers
Printer ink full but will only print color on doc not black txt..
Epsons love to be used, hate to stand around. They employ a ceramic printhead that will tolerate thousands of pages and do them all well but not using it for a while (sometimes only two weeks) can cause the printhead to dry out and never return to usefulness.
About the only thing you can do is to repeatedly run the printhead cleaning routine over and over again. If you are lucky, Epson allows you to which path (Black or color only) to attempt to clean. Good luck; I have had to retire several Epsons after a fairly short life for this problem.
Printer only printing tops of words
Depending on the printer, you must wither change the ink cartridge, clean the printhead or replace the printhead. They are not all the same. If it's a dot printer, make sure the ribbon is in correctly.
Gremlin11
Printing solid black lines 1/2 high where the actualy print should be
the printhead resistor are done , you will need to replace the whole printhead
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
