Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
A
Anonymous Posted on Aug 17, 2014
How to unlock the door - Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
Dado
Level 3:
Master:
  • Ariston Tech... Master 511 Answers
  • Posted on Oct 28, 2015
Dado
Level 3:
Master:
Answers
511
Questions
0
Helped
482511
Points
1313
Lamp M flashes slowly when the appliance is switched on and
a waiting instructions and at the end of a cycle, indicating that the door can be opened. It flashes quickly when the door should not be opened. A steady light means the appliance has accepted the selected programme.
How to unlock the door - 24967037-ineink0kisfnom0atbkujjcx-3-1.jpg If you correctly use the appliance then defective can be interlock, wiring or board.
If the door is constantly locked then you can access to interlock by removing the top cover of washing machine.
Dado
Door lock receiver on a2001 Pontiac Grand am
Do they work with the key fob, do you have one of those? They lock when put into gear an unlock when put into park because the BCM - body control module does that .
Door Lock System Components
The power door lock system consists of the following components:
• Driver door lock switch
• Front Passenger door lock switch
• Body Control Module (BCM)
• Relays: Driver Door Unlock -- on vehicles with RFA, Door Unlock, and Door Lock
• Door Lock fuse 15A
Door Lock System Controls
The power door lock system can be controlled by any of the following:
• A power door lock switch activation
• A keyless entry command -- if equipped with keyless entry
Driver and Passenger Door Lock Operation
When any of the door lock switches is pressed to the lock position, the BCM door lock/unlock signal circuit changes from an idle voltage of ~3.4 volts to 0.0 volts generating a lock command. The BCM then applies battery positive voltage to the Door Lock Relay, which in turn applies battery positive voltage to the Door Lock Actuator lock circuit of all the Door Lock Actuators. Since the Door Lock Actuator unlock circuits are held to ground through the resting Door Unlock Relay(s), the actuators execute the lock command, locking the doors.
The lock function can also be accomplished by the BCM having received a keyless entry door lock command, if the vehicle is equipped with keyless entry.
Driver and Passenger Door Unlock Operation
When any of the door lock switches is pressed to the unlock position, the BCM door lock/unlock signal circuit changes from an idle voltage of ~3.4 volts to ~1.7 volts generating an unlock command. The BCM then applies battery positive voltage to the Door Unlock Relay and the Driver Door Unlock Relay when equipped with keyless entry, the relay(s) in turn apply battery positive voltage to the Door Lock Actuator unlock circuit of all the Door Lock Actuators. Since the Door Lock Actuator lock circuits are held to ground through the resting Door Lock Relay, the actuators execute the unlock command, unlocking the doors.
The unlock function can also be accomplished by the BCM having received a keyless entry door unlock command, if the vehicle is equipped with keyless entry. Keyless entry personalization allows the driver door to be unlocked individually before unlocking the passenger doors. When this feature is active, the BCM will require a repeated unlock command to unlock the passenger doors.
Automatic Door Lock/Unlock
The automatic door lock/unlock function is a Vehicle Personalization feature with the following four programmable modes of operation:
The automatic door lock feature is disabled.
All of the doors lock when the vehicle is shifted out of Park with the ignition ON.
All of the doors lock when the vehicle is shifted out of Park with the ignition ON, and all of the doors Unlock when the vehicle is shifted into Park.
All of the doors lock when the vehicle is shifted out of Park with the ignition ON, and only the driver door Unlocks when the vehicle is shifted into Park.
For information on programming the automatic door locks, refer to Vehicle Personalization in Personalization.
1helpful
2010 Equinox doors keep unlocking after the car is parked killing the battery
Could be any number of thing's causing this problem . Knowing what all is involved in the locking an unlocking of the doors is key . Computer controlled by the BCM - body control module , relays ,wiring ,switches etc... Bad input from switch or grounding wire to the BCM could make the BCM think door unlock has been requested .
• Driver door lock switch--Provides a switched voltage signal to the body control module (BCM) for both lock and unlock switch activations.
• Front passenger door lock switch--Provides a switched voltage signal to the BCM for both lock and unlock switch activations.
• Door lock relay--Located in the instrument panel (I/P) fuse block and controls the locking of all doors and liftgate.
• Door unlock relay--Located in the I/P fuse block and controls the unlocking of the passenger doors and liftgate.
• Driver door unlock relay--Located in the I/P fuse block and controls the unlocking of the driver door.
• BCM--Class 2 module which requires programming when replaced
• Reversible door lock actuators in each of the doors
• LOCK/MIRROR 10 A fuse--Located in the I/P fuse block, supplies power for the door lock switches and relays.
• DR LCK 20 A fuse--Located in the I/P fuse block, supplies power to the relays
• Power door lock switch activation
• Keyless entry lock or unlock command
• Delayed locking command
• Automatic door lock command
• Lockout prevention command
• An air bag deployment
Door Lock and Unlock Operation
When a door lock switch is activated in the lock or unlock position the body control module (BCM) will receive a voltage signal on either the door lock switch lock or unlock signal circuits.
The BCM, upon receipt of a lock switch lock or unlock signal, will switch the appropriate lock relay control circuit(s) to battery positive voltage. This will energize the appropriate lock or unlock relay(s). The relay will supply voltage to the door lock actuator lock or unlock control circuits to one side of the lock actuator. Since the opposing side of the lock actuators are connected to ground through the other lock actuator control circuit and the normally closed contacts of the lock or unlock relay, the doors and liftgate will then lock or unlock appropriately.
Three relays are used to operate the lock. Driver door unlock, passenger door unlock and all door lock. This is done to isolate the driver door lock actuator so it can be unlocked by itself using the keyless entry transmitter.
Automatic Door Lock Operation
This body control module (BCM) controlled feature can be personalized to driver preference.
The BCM will automatically lock the vehicle doors if the following conditions exist:
• All vehicles doors are closed.
• The ignition is in the ON position.
• The vehicle is shifted out of PARK.
The BCM will then unlock the doors when the ignition is placed in the OFF position.
The first thing ,hook up a professional type scan tool an check for DTC'S in the BCM
DTC Descriptors
DTC B3140 00: Driver Unlock Switch Circuit
DTC B3145 00: Passenger Unlock Switch Circuit
DTC B3150 00: Driver Lock Switch Circuit
DTC B3155 00: Right Front Lock Switch Circuit
DTC B3130 00: All Door Unlock Circuit
2helpful
2answers
2008 Saturn vue XR key fob and door unlock button will not unlock all the doors. Is there a fuse that needs replaced?
key fob and door unlock button will not unlock all the doors ???? None ? Drivers door lock , passengers doors ???
I have a 2008 Chevy Malibu inside door locks don’t work like theirs no power no does not click on inside to lock when you’re in the car nor outside when you put the key in the outside lock it only locks...
Probably not a whole lot your going to be able to do ,Unless you have a factory or some other professional type scan tool to check for DTC'S - diagnostic trouble code's , an have service repair info for power locks for your car . Computer controlled (BCM) - body control module .
The Power Door Lock System consists of the following components:
• Body control module (BCM)
• Reversible door lock actuator in each of the doors
• IBCM (PWR) 15-amp fuse
• Driver door cylinder switch, if equipped
The Power Door Lock System is controlled by the body control module (BCM) and can be activated by any one of the following:
• A door lock switch lock or unlock actuation
• A keyless entry transmitter actuation
• An automatic door lock or unlock actuation
• A last door closed locking (LDCL) actuation
If the driver door cylinder switch feature of the vehicle is functional, the locks may also be operated by a driver door cylinder switch lock or unlock activation
Power Door Lock Switch Operation
Each door lock switch is wired to the body control module (BCM) through a separate door lock/unlock signal circuit. While these circuits are separated between the BCM and respective door lock switch, they are connected into a single circuit within the BCM. The BCM supplies voltage through the door lock/unlock signal circuits to each door lock switch. When either door lock switch is operated, this supply voltage is pulled to ground, providing the BCM with the required lock or unlock signal. In order for the BCM to distinguish between a lock and unlock signal, the lock switch contains two separate paths for this voltage to flow to the same body ground. When the switch is operated to the unlock position, the supply voltage flows to ground through a 1.5 K? resistor. When the switch is operated to the lock position, the supply voltage flows to ground through a different part of the switch circuit, which has no resistor. The BCM then interprets the flow of voltage as a lock or unlock request and powers the door lock actuators to the appropriate lock or unlock position.
Power Door Lock Actuators
The body control module (BCM) powers the reversible door lock actuators by providing battery positive voltage and ground to the appropriate lock and unlock control circuits of the actuators. The Lock control circuits of the driver and passenger door lock actuators are all connected together, however, the Unlock control circuits are connected in a slightly different way. While the unlock control circuits for the passenger door lock actuators are connected together, the driver door lock actuator has a separate unlock control circuit. The system is designed this way so that the keyless entry transmitter may be used to unlock only the driver door. Despite this difference, all of the lock actuators perform much the same way. When the door lock actuators are not active, all actuator Lock and Unlock control circuits are at ground potential within the BCM. Transitioning of the lock actuators to the lock or unlocked position depends upon which control circuits receive voltage and which control circuits receive ground.
• If the BCM is commanding the door lock actuators to Lock, it momentarily switches the lock control circuits to voltage. Since the unlock control circuits are at ground potential within the BCM, the actuators transition to the Lock position.
• If the BCM is commanding all door lock actuators to Unlock, it momentarily switches the unlock control circuits for both the driver and passenger door lock actuators to voltage. Since the lock control circuits are at ground potential within the BCM, all lock actuators transition to the Unlock position.
• If the BCM is commanding only the driver door lock actuator to Unlock, it momentarily switches only the driver door actuator unlock control circuit to voltage. Since the lock control circuit is at ground potential within the BCM, the actuator transitions to the Unlock position.
Power Door Lock and Unlock Operation w/Keyless Entry Transmitter
The keyless entry transmitter may be used to unlock only the driver door. When the unlock button of the keyless entry transmitter is pressed once, the body control module (BCM) receives the unlock request from the remote control door lock receiver (RCDLR). The BCM interprets this single press as an unlock driver door request and responds by switching only the driver door lock actuator unlock control circuit to voltage. With the lock actuator lock control circuit for the driver door at ground potential within the BCM, the driver door lock actuator transitions to Unlock.
If the unlock button of the keyless entry transmitter is pressed a second time within three seconds of the first press, the BCM interprets this second press as a request to unlock the passenger doors and responds by switching the passenger door unlock control circuits to voltage. With the lock actuator lock control circuits at ground potential within the BCM, the passenger door locks transition to Unlock.
To lock all doors with the keyless entry transmitter, a single press of the transmitter lock button is all that is ever needed. The BCM receives the lock doors request from the RCDLR and responds by switching all lock actuator lock control circuits to battery voltage. With the actuator unlock control circuits at ground within the BCM, all actuators transition to Lock.
1helpful
Where are the fuses for the power dock locks on a 2006 montecarlo06ss
DR/LCK fuse 25 amp . located in the I/P block
Fuse Block - I/P
In the right front kick panel
Power Door Locks System Components
The power lock system consists of the following components:
• Driver door lock cylinder switch
• Front passenger door lock cylinder switch
• Door lock actuators in each of the doors
• DR LK Fuse 20-amp
• A door lock cylinder switch unlock actuation
• An automatic door lock actuation (Personalization function)
• An automatic door unlock actuation (Personalization function)
Door Lock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the lock position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the lock position.
Driver Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the left front (LF) door lock actuator motor transitions to the Unlock position.
The driver door lock actuator unlock control circuit is a dedicated control circuit used only for the driver door lock actuator motor. This is done so that the driver door may be unlocked by itself using a keyless entry transmitter or an automatic door unlock function (if programmed).
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked separate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed).
2005 Buick Rendezvous you can hear the relay clicking but the door locks will not open and close
Check for broke wires inside the boot from body to driver door , this is a common problem . If you don't find broke wire's , pull the door panel to get at driver door switch . Check for voltage an ground circuit .
Rendezvous Door Lock System Components
Door lock system fuse into the BCM (BCM D 25A fuse)
Door Lock Operation
When the BCM detects a transition of either of the door lock switches to the LOCK position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the Lock position.
When the BCM detects a transition of either of the door lock switches to the UNLOCK position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the LF door lock actuator motor transitions to the Unlock position.
When the BCM detects a transition of either of the door lock switches to the UNLOCK position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the Unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked seperate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed). This video on testing computer controlled door locks on a Subaru , doesn't matter . test yours same way > The BCM controls your door locks .
Are all of the power door locks inoperative from both door lock switches?
1helpful
Driver side door will not lock/unlock with the remote, but the other doors will.
no you needs a new lock actuator on that door its about $90 installed,
all the locks are on same circuit . sorry about the bad news :(
Passenger door locks don't unlock.
You need to understand how they work , do you know about automotive electronic controls ? Your switches are just inputs to the BCM - body control module !
Door Locks Power and Ground
For door lock operation, the IP Fuse Block supplies battery positive voltage, through the 15 amp DR LK/TRUNK fuse, to the BCM. The BCM uses this circuit exclusively to apply power to the door lock actuators. The BCM is also supplied a ground circuit, which it uses exclusively to ground the door lock actuators. When a door lock is pulsed, the BCM internally connects these two circuits to the appropriate lock and unlock control circuits to actuate the locking or unlocking functions.
When diagnosing door lock malfunctions, these circuits must not be confused with the other battery voltage and ground circuits of the BCM. The appropriate wiring schematic must be used to locate the correct circuits. Failure to identify the correct battery voltage and ground circuits of the BCM during diagnosis of door lock concerns may result in misdiagnosis and unneccessary parts replacement.
When the BCM detects a transition of either of the door lock switches to the Unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuators transition to the Unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuators. This is done so that the driver door may be unlocked individually before unlocking the passenger doors using a keyless entry transmitter or an automatic door unlock function, if programmed. When the keyless entry transmitter is used to unlock the passenger doors, the BCM requires a repeated unlock command before it performs the unlock function. However, when the unlock input is from a door lock switch, a single unlock command is all that is required to unlock all doors.
How to test computer controlled door locks
1helpful
Driver side door locking with remote but will not unlock, if i unlock it with key then remote will unlock all other door, if all doors are locked remote will not unlock the car. Once i manually unlock...
it is not the actuators, try a different remote, you may have an issue with the car security system/body computer not functioning on the unlock driver door command, one press of remote is unlock driver door and 2 presses is unlock the other doors.
My 1989 Chrysler LeBaron with power door locks has the paasenger side door jammed. Any ideas on how to unjam it?
Hi
If the Problem is That you Can't Unlock the Door With Door Unlock Switch, Or The Key Outside of Door, nor can you Unlock Door with Manual Unlock Button [ Electrical Lock Doors Only ] Then More than Likley The lock / Unlock Motor that electricaly Locks and unlocks the Door has become Defective and is Jamming the ability to Unlock the Door by any method. You will have to find some way to get to the Mechinisim to move the door lock to the Unlock Position before you can open the Door. This will be very hard with the Door Closed but you may be able to remove the cover over the inside door handle and with some moveing of the link to the lock / unlock mechensim to get the door Unlocked. If not you may have to take it to your dealer or a body shop to see if they can get the Door unlocked. Try not to force unlock with a key as this will damage the Keylock Mechinism.
Then you will have to replace the Door lock / unlock Motor or simply disconnect the linkage to the door lock / unlock Motor and use a key to lock / unlock the Door untill you can replace the motor.
This is a common problem that shows up in these older cars. In my case both of the door lock motors on my 1987 Lebaron went out about the same time but the Pasenger went out first.
Usually the first indication that this problem is about to occure is you find that the Door lock becomes harder to lock and unlock with the key or with the manual door lock button.
Frank
Top Ariston Technologies Washing Machines Experts
ZJ Limited
ZJ Limited
vince
ADMIN Andrew
ADMIN Andrew
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
