JVC LT-32P679 32 in. LCD TV Logo
Bobbi Lee Posted on Aug 18, 2014
Dark picture jvc
Dark part of pic is too dark, have tried adjusting, gamma on
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Mar 23, 2007
SOURCE: Rear projection dark picture
Open up the front of the set and find the screen controls and perform a grey scal alighnment by adjusting the red , blue , and green screen controls but be carefull and make sure you adjust them evenly or the picture will not look right. Good Luck
Anonymous
  • 3 Answers
  • Posted on May 15, 2008
SOURCE: Dark picture
**WORKS**
In my case, the adjustment was available from outside the TV. Sortof. On the rear of the TVabout 2 inches to the right of the coax in, there are two vertical slits on a little protrusion. Inside the slits are the two adjustment screws. The lower screw adjusts brightness, the upper screw adjusts focus.
Anonymous
  • 189 Answers
  • Posted on Oct 19, 2008
SOURCE: Picture is too dark
How many years is your TV now? Usually TV has its life span, there comes a time that it happens. And need to look for a technicians, cause some of theme can still be repair by adjusting the brightness inside your TV.
sparky1500
Matthew Spark
  • 1066 Answers
  • Posted on Nov 28, 2008
SOURCE: TV screen went dark, but sound still there.
your backlight burnt out, this will be a maybe several hundred dollar repair. the screen is backilt by a very expensive flourescent light, without that light, the screen will be black.
Anonymous
  • Posted on Jul 11, 2010
SOURCE: Picture on tv JVC 27" AV-27530 is getting to dark
I have the AV-27S33 model and in the rear to the right of the inputs are two slits and inside these slits are two screws. The top screw is the focus,the bottom the brightness.Your tv is a different model but it may have this same adjustment,if it does try turning the bottom screw to the right to increase the brightness.
1helpful
My Ecco TV is playing but the problem is pic is not clear it's dark . Please help
The screen may become dark if Picture mode is set to Cinema or Custom. If the screen continues to remain dark after changing the picture quality mode, go to the Backlight, Picture, Brightness menu and adjust the brightness to your liking. When Power Saving is fixed to Low or High, the screen becomes dark. Some TVs have a Light Sensor so the picture will just become brighter or darker depending on the lighting in the room.
You can also try programming from a different source, like a DVD player or VCR to check whether the problem is caused by the device that sends the signal to the TV.
My tv screen is to dark how do I lighten the picture
If your TV has already fully adjusted in brightness set up?, and there will be no good picture results?...try to adjust the "SCREEN-Screw" at the flyback slowly. If the picture still dark'?. the picture tube has need to rejuvenate.
Jvc #av27d304. pic is to red and dark.night scenes are almost blackcant make out a thing
You could try adjusting the A1 voltage bu it doesn't go out on its own. Maybe a tube required?
I have a JVC tv only 1 year old and the picture is getting dark.
have you tryed adjusting the picture in the menu section! this may help!! or on back of tv is adjusters those may help as well.
3helpful
Picture getting dark
My jvc 27" tv was so dark I could hardly see any night scenes, even with the bright all the way on. If you push the sleep button, let go, then hold down the video and display (together), the service menu will come on. Scroll down to #7 (too dark) and adjust the brightness there. Works immediately. Good luck.
TCL TV picture too dark
try turning the light sensor off
Picture is too dark
Cannot readjust
sounds like a clasic tube failing sooner or later it will be so dark u wont be able to adjust it or it will just loose the pic all together sorry for the bad news:)
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
