Http://www.multi-region.net/samsung
Look here for an unlock code. Or google you player and unlock code. Then no more regions....yay
SOURCE: regional code change for a samsung ht-db120n
1) Disconnect your player from its power source for thirty seconds 2) Reconnect your player to its power source 3) Press the Power On button on your remote control 4) Press the Enter button on your remote control 5) Press the 8 button on your remote control 6) Press the 4 button on your remote control 7) Press the 2 button on your remote control 8) Press the 6 button on your remote control 9) Press the 9 button on your remote control 10)Press the Enter button on your remote control 11)Your player should now place itself in Standby mode 12)Press the Power On button on your remote control. Your player is now region free. A word of caution is that you may have disc eject issues, in which case you will have to eject from the unit, or toggle the power switch on/off. This issue only arises if you have a particular chipset in your player (about a 20% chance).....good luck my friend.
SOURCE: unlock home theater system samsung ht-x20
http://www.videohelp.com/dvdhacks/samsung-ht-x20/8981
This should solve it :) I had similar problems.
Swapnil
SOURCE: Sammi Jones must be an Indian spammer on FIXYA --- samsung HT x20 region code
For Samsung HT-X20 the region code unlock listed workd perfectly. Just hit 8,4,2,6,9 then ENTER (do this twice) and it will play your DVD which it did not before.
Abe
SOURCE: Samsung HT-TX500 region free
hi there
i live in Thailand and just made my HT-TX500 region free,
this is what i did
your dvd must be off with no dvd inside
push power on wait til no disc come up then push enter
then push 84269 then push enter then wait for the dvd to turn off
wait 5 mins.then push power on and that worked for me
SOURCE: I need to reset the region code on a samsung home
Hi
Thanks for using FixYa. Please follow this procedure to reset the region code (or to make it region free).
Open tray and remove any disks in tray, then Close the tray.
1. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM)
2. Reconnect to mains
3. Turn on player with remote.
4. Press ENTER on remote.
5. Press 8, 4, 2, 6, 9. Using keys on remote.if your player is already set to region 2
6. Press ENTER on remote. (The tray will open and player will power off and close tray.)
7. Switch on power from remote.
8. Player is now Region Free.
Allows both region 1 & 2 DVD's to play.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
