This camera appeared lens obstructed .what is the reason for this problem.when it is one this massage is given.i want to know the solution for it
SOURCE: kodak camera dropped lens cockeyed stuck open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
SOURCE: My Kodak af 3x optical aspheric lens camera won't turn on
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
SOURCE: how to install fisheye lens and adapter on kodak
No, you do not remove the existing lens. You need to purchase a lens adapter tube that fits around the existing lense. This adapter threads onto the inside bezel on the camera at the base of the lens assembly. Additional converter lenses and filters fit onto this. My adapter has 55mm threading for filters.
SOURCE: Kodak Easy share C182 Digital Camera
Please check that you have putted kodak alkaline batteries.
SOURCE: my kodak c195 keeps saying
There is a tiny motor that extends and retracts the lens, sometimes it will jam because part of the gear breaks causing it to malfunction, I would imagine the cost to repair will be high
