Gas shooting out of rubber hose above carburator. craftsman lt200 with kohler engine.
If hose coming off carburator does not connect to anything then it is the over flow for carburator when float gets stuck and does not close needle valve causing excess fuel in carburator bowl and is drained automatically through vent orfice connected to hose that gas is dripping from. If this is the case then remove carburator bowl, check float, needle valve and o-ring in where needle valve goes. sometimes when carburators sit over winter with gas in them the gas breaks down and over time will gel/harden and cause float to hang up and o-ring for needle valve to deteriate and not sealing properly. clean and replace parts as nessesary.
I hope this helped.
