Question about Sharp R-1480 Microwave Oven
Sharp carousel 1200 watts microwave manual
Not working as designed when door is closed the turn table starts turning and only stops when door is opened you can not set a time
    New Friend:
  • 44 Answers
They is one of the DOOR SWITCH need to replace
Posted on Sep 24, 2014
6ya staff
SOURCE:
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Sharp carousel under counter microwave start doesn't always work
Sounds like an intermittent door switch or a loose door switch mount. Very common.
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Oct 22, 2007
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Sharp Microwave oven controls do not work
You mean the turntable motor turns whenever the door is shut, even if you're not cooking?
If that's the case, then the problem would probably be a stuck relay (RY3) on the control circuit board, which we regularly repair nationwide for $39.95 postpaid.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
If you have a different problem than I described, please reply back with details before you give us your rating.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 19, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Posted on Apr 18, 2008
victor williams
  • 78 Answers
SOURCE: All lights on the front
you might need to replace the door switch
Posted on Jan 27, 2011
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Sharp Microwave 1200 Watt Carousel
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 -==-
Posted on Aug 13, 2011
Microwave arching
faulty microwave module replace it
Apr 22, 2015 | Sharp R530EWT Countertop Microwave Oven...
My microwave stopped working you can input time but when you push start nothing happens it has power and everything just will not start its like the start button does not work
Possibly a bad door switch behind the holes where the latch hooks go into. Usually with the bad switch the timer counts down but nothing runs. It all depends on which switch is bad. Usually 3 switches inside.
Apr 13, 2015 | Sharp R530EWT Countertop Microwave Oven...
My microwave is 25 years old, will it be working to maximum efficiency
If all the settings work and the door closes ok . why throw it out ?. It may not be quite as efficient power wise as a brand new one. the few cents extra to run it against the price of a new one, I would stay with old faithful.
Dec 31, 2014 | Sharp R530EWT Countertop Microwave Oven...
How to fix loud hum and no heating in Sharp model R-308KW?
There could be a variety of reasons why this happens, but the likeliest
reason is the secondary interlock or monitor switch is broken. These are micro switches that tell the microwave that the door is closed. If this switch is broken, then the microwave thinks the door is still open and the carousel table won't turn, and the oven will not heat up.
I replaced an interlock switch last Saturday. The switch was $7.00 and took me an hour.
Ask your local repair person to test the interlock and monitor switches first, then go from there.
Good luck,
Hank
Jul 09, 2014 | Sharp R-308KK / R-308KW 1100 Watts...
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
I have a Sharp Carousel microwave model R438DV 1200 watts. There is a small 5x7 screen on the right side wall. It now has a small hole and has char marks on it. When I use the unit a fire starts o
You have to replace that small screen which is called wave guide. If there is a sharp authorised service centre near to your place you can buy the part from them. Do not work the oven without replacing that part.
May 29, 2009 | Microwave Ovens
My convection/microwave quit rotating.
Hello Tina,
Usually those turn tables(or lazy Susan's colloquially) are driven by a small motor. The motor attaches to a gear or spindle which transfer the rotational energy to the turn table. A plastic gear may have been broken or popped loose. It might also use a belt to transfer the energy, the belt could have worn and is now slipping which would cause the table to stay stationary.
Aug 10, 2017 | Sharp R-370E 1000 Watts Microwave Oven
Sharp R-1480 Microwave Oven Logo
308 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ekse
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
