This means one of the cartridges is defective, they cant align if they cant print. What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center. When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in. I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black. Basically you align the cartridges and then swap them so the printer thinks they are still aligned. The color still doesnt work and it is probably a defective color cartridge.
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
I have the same problem. Everything on the printer is working just fine. It'll do a test page just fine, so everything's working right. The %$^ thing just won't print. It makes noise like it's printing when you give it a print job, but it spits out blank pages.
The issue with the Action Replay not staying inserted into the DSi may be due to a loose or damaged cartridge slot on the DSi or an issue with the Action Replay cartridge itself.
Check the Action Replay cartridge for any visible damage, including bent pins or connectors. If you find any, it may need to be repaired or replaced.
Try inserting other game cartridges into your DSi to see if they fit securely. If other cartridges also don't stay in place, it could indicate a problem with the DSi's cartridge slot.
DSi Not Recognizing Game Cartridge:
If your DSi doesn't recognize that there's a game in the slot, this could be related to the Action Replay cartridge, or it could be a more general issue with the DSi.
Test this issue with regular game cartridges that are known to work. If the DSi still doesn't recognize them, there may be a problem with the cartridge slot.
If other game cartridges work fine, the issue may be specific to the Action Replay. In this case, you should contact the manufacturer or distributor for support or a replacement.
In either case, if the problem persists, you may want to consider having your DSi and Action Replay inspected or repaired by a professional technician, or contact Nintendo's customer support for further assistance. Make sure to follow their guidance and ensure that your DSi and accessories are in good working condition.
