CANNOT CLEAR FATAL ERROR MESSAGE
I have this problems FATAL ERROR, i repair it with the original memory card i have save on my computer.I paste it over the faulty memory cards and my gps is o.k..if you want the original memory cards tell me.
[email protected]
The memory card might have been dislodged. Remove memory card, turn on unit, perform a destination function [city,street house no.] without the memory card. The unit won't be able to calculate destination, therefore unplug it. Wait 3 minutes, insert memory card and turn on unit, then perform destination functions. If it works, also do the touch calibration of the unit.
Link no respond
My finedrive 400 is not turn on
I have an older one of these with the AV connections. once in a while it does not see GPS signals. If I exit navigation and from the main menu select setup, I can reset the GPS and then go back into navigation, this seems to cure the issue but it may return. I think the root cause is a low memory battery in the unit.
The only way to cure this issue is to reload the firmware, as finedrive is no longer helping customers, I posted the files to do this online:
here is the link to the instructions and install data.
http://www.flyupload.com/?fid=951808
install data
http://www.flyupload.com/?fid=6960824
and the map data
http://www.flyupload.com/?fid=9768281
my GPS was working all these days for 1 year and now it doesnot even start, is there any problem with battery inside my GPS? mine is Fine Drive 400.
fatal error
I have same problem like come massage on the screen FATAL ERROR and contact to program vender.
no maps on my fine drive where ? link explicated is broken
Hi to all I have a fine drive 400 and yes I have the same problem fatal error comes up and that's it ?? I tried to get in touch with costumer service but no luck ?? like to now how to fix this problem . or do I buy A new GPS .Can anybody HELP WITH THIS PROBLEM
Tom
Just bought the Nextar GPS yesterday. Left on charger all night and when I turned it on this morning I got a screen with red white and blue vertical streaks. Just tried it again and got fatal application error on right side of screen, can't read it all, but it says exception 0XC0000005. Address: 03FC38A8.
got NEXTAR fatal appication,error except 0x80000002, address000E6ED8 HAPPEN ON 15000 TRIP MOVING HOUSEHOLD ITEMS FROM ON PLACE TO ANOTHER AND IT TOO ME A HR TO FIND THE RIGHT MOVE. ART.
