I purchased a HP EliteDisplay E221 monitor. I have about a two year old HP pavilion dm4. After hooking the together, I cannot get the info on the new monitor to pivot to 90, even after installing the new drivers on the CD which cam with the monitor and using the HP Display Assistant in both auto pivot and manual pivot modes. Any thoughts?
Here is a link to a web site that offers few notes on how to enable the feature in the windows OS environment:
Pivot Feature Does Not Work
SOURCE: HP Monitor blanking out on full screen mode
Hi, I read this somewhere (can't recall the site). Go to your desktop properties (right click on any clear area of your desktop); Settings tab; Advanced button; Troubleshoot Tab; Uncheck Enable Write combining; Reboot your PC. If this does not fix the problem, you can always revert back. Hope this be of some help. Good luck and kind regards.
SOURCE: Shaking Problem with LCD Screen - HP Pavilion F1703
It sounds like you need to use your "DeGausse" button to reset the magnetics in the screen.
SOURCE: HP Monitor goes into sleep mode
Problem of monitor sreen going black in 5-10 secs is generally dry solder joints around the inverter transformer on the inverter PCB.
SOURCE: problem on hp monitor
I know you said there were others that had the
same problem with the Main Menu coming up and I thought I would tell you
what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and
slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back
cover.
At the bottom of the monitor case, there is a small circuit board the
holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second
switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence
while holding the switch with a pair of needle nose pliers. I had to
rotate this process from one prong to the other while all the time
applying slight pulling pressure on the switch pulling it away from the
circuit board.
8. Once the switch was removed, I put the cover back on and tightened
up the five screws.
9. Then I slid the base back in the slot it came from and tightened the
four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so
very happy.
I have a Dell E171FPB monitor that had the
slid the stand off.
cover.
circuit board.
up the five screws.
four screws.
very happy.
