Access to remove switch
Hello friend, thank you for your post!
I see you are attempting to replace the switch on your Frigidaire oven. Some of these intricate parts do require precision and patience, therefore when replacing the exchange of such electrical components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Matt
In order to test the surface burner on your electric range, the following steps should be taken:
An oven thermostat is a switch that opens and closes in response to the temperature
it senses. It is typically found in the control panel, where a
liquid-filled temperature-sensing bulb senses and maintains the internal
oven temperature by cycling heat on and off.
Adjusting the thermostat:
