WPS is a novel technology that lets various devices interact with each other. Using WPS you could establish a secure link between a myriad of devices and one advantage of WPS is that it is faster when compared to USB.
WPS pin is an 8-digit code formulated by the HP printer which helps establish a robust link between the printer and the system. The notable characteristic of this technology is that it is completely secure and filters out all unnecessary connections. WPS is a technology that would be implemented in all printers in near future. So it is becoming essential to know where is the WPS pin located on my hp printer to utilize this phenomenal feature.
Also, the PIN number is usually found on the router's setup pages. You have to use the router's PIN for devices to connect to it. Sometimes there will be a sticker on the back of the router with the PIN number on it.
Wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices.
WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
