Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
A
Anonymous Posted on Aug 15, 2014
Evinrude year serial number. 6102e-J03277
What year. And is it a 2 cycle or a 4 cycle
phillipelecu
Level 2:
Champion:
  • Expert 254 Answers
  • Posted on Aug 16, 2014
phillipelecu
Expert
Level 2:
Champion:
Answers
254
Questions
0
Helped
71211
Points
313
1971 6 HP, It has to be 2 cycle. 50:1 premix. Great little motor.
Curious to know the year, H.P., and if this Evinrude motor is 2 or 4 cyc. Model # 60452S, serial # E01871. Thank You!
There is a model 60452 listed under 60hp, 1964year. Not sure what the S means, but in the 60's they were 2 cycle. I don't think 4 cycle came out until the 80's. Evinrude Outboard Motor Model Numbers
Jun 22, 2019 • Boating
Need yr for evinrude E8RLNR
Bruce,
Do you have the serial number of the motor? Reason I ask is twofold. Evinrude started using this model number layout as of 1980. Having said this, something is not making sense with the location of the "N" in your model number. Those last two letters as of 1980 are the year. Here is the chart. Letter on top with corresponding year below it.
I N T R O D U C E S
1 2 3 4 5 6 7 8 9 0
So... Example
1980= CS
1990= ES
2000= SS
2010= IS
You have E8RLNR which breaks down as:
E= Evinrude
8= 8hp
R= Rope start tiller steering
L= 20" shaft
N= 2nd year
R= 4th year
I would expect to see the N in the last spot:
1982= CN
1992= EN
etc.
Serial number is another way to identify the year.
This may hep point you in the right direction. Hope it helps.
marineengine.com/parts/engine-model-guides/omc-johnson-evinrude-model-number-guide/omc-johnson-evinrude-model-number-guide-00004.html
Regards,
Fred
I have a 1998 model E25RMECA I NEED TO KNOW WHAT TYPE GAS TO USE IN IT. AND IF IT IS 2 CYCLE OR 4CYCLE.
I found a mixture of sites for the information
one owner of a 1998 25 hp evinrude says that it is a 2 stroke with a fuel mix ratio of 50:1 as 25:1 is a bit smokey
another site says that the recommended octane fuel rating is 87 although it might run better on 91
best advice is to find an evinrude service dealer and get the right information as the later 25 hp units are etec engine which will be 4 strokes
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
What year is this evinrude 135 hp boat motor? serial #j0007646
To have the year of your engine, we'll need the engine typenumber, not the serial number...
2answers
What is the year model of a evinrude outboard motor with the serial number 1503201749
try reading this on ehow http://www.ehow.com/facts_7292301_evinrude-year-identification.html
Year model serial number
1978 It is in the model on an Evinrude. 6804.... 6 HP.....1978
Top Light Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
john h
Are you a Light Boating Expert? Answer questions, earn points and help others
