28 hp Briggs and Stratton
SOURCE: Husqvarna 24 hp mower shuts down after about 5 or 10 min.
I WOULD LOOK FOR AN ELECTRICAL (IGNITION) SHUTDOWN,CHECK WHEN IT SHUTS DOWN WITH SPARK TESTER TO SEE IF IT IS FIRING.
SOURCE: what kind of oil for a husqvarna riding mower?
Yes Briggs and Stratton recommends sae 30 in most all their engines even overhead valve (OHV)
Kohler uses 10w-30 in most of their overhead valve engines
Briggs has their own bottled oil with their label and additives and can find at lowes
Kohler the same
SOURCE: mower keeps cutting off
my brother had the same problem with same mower. he took it to service station new plugs etc. still did it he took his back maybe problem with the magneto/ coil since you only have 12 hours on it, take it back and get a different make ie john deere or cub cadet husqvarna riders are junk!!!!!
SOURCE: Briggs and stratton 24 HP model ELS 725 mower
A great expedient spark tester can be made from an old spark plug that you know is GOOD.....clip or grind the grounding terminal ( the terminal which goes over the top of the electrode) back until you have a gap of 1/8 to 3/16 of an inch between the terminal and the electrode...Remove both plugs from the machine and attach your new test plug to the plug wire. Ground the plug by placing it on the head or the shroud. Turn the machine over. If you are getting fire you should see a strong blue spark shoot from the electrode to the terminal. If you have no fire then you probably have a bad ignition coil, bad plug wire, or maybe just a bad seat, brake, or PTO safety switch...I'd check these first. Also check your ignition switch in the run position with a test light to be sure it is good....hope this helps... ;-D
SOURCE: 12 hp briggs and stratton starter
the battery may be to weak try jumping it with your car its the same voltage the starter needs to spin out fast to in gauge
