Bluetooth
If you want the stock bluetooth module you will have to either call hp and buy it from their spare parts dept. or go to a site like ebay to buy it. after you have acquired the card (and cable), you will need to disassemble the laptop and install the card in it's designated spot(I think it's located near the right had corner closest to you as you look at the laptop in it's normal use orientation. The alternative to this is to get a usb bluetooth card.
SOURCE: I have HP Pavilion DV6
If your particular model of HP has the blue tooth installed from the
factory, turning on the wireless switch on the front left edge of the
laptop enables the blue tooth, as well as the wireless LAN. A blue tooth
icon should appear in your task bar near the clock when blue tooth is
turned on.
ELSE
You have to go into start, then all programs, then look for the blue tooth connection setting. Hope this helps.
Go into start, then all programs, then look for accessories, the find blue tooth wizard. You can switch it on via that.
NOTE : BE SURE THAT YOU HAVE A BLUE TOOTH IN YOUR MODEL BECAUSE SOME OF THE MODELS DON'T HAVE IT.
SOURCE: i cannot locate my bluetooth on hp pavilion dm4 1162us
Hi ,
You'll find bluetooth in the control panel . providing your operating system offers it .
and unless its built in to your computer , it takes a bluetooth usb adapter let me know if this helps you , and i will advise futher ..............Goodluck Roy
1) you NEED tune up your computer.Normally the computer has integrated the software for solution and get integrated the software diagnostics, and TUNE UP use it.
2) uninstalled programs
3) clean for cookies,etc
4)updated your computer from window
5) pass the AntiViurs +Malware software
6) pass the Check disk from your local disk, etc
Try it , otherwise you must go to the repair shop computer for fix it.
