Question about Schwinn 430 Elliptical Trainer
How to put battery in console elliptical
Console
3 Suggested Answers
Anonymous
SOURCE:
Anonymous
SOURCE: The console does not work. E-2 shows up on the console.
We had this problem after assembly as well, it turned out to be a bent pin inside the connector to the flywheel housing (where the wires connect inside the lower part of the main mast). It was so bent that it never actually made contact with the connector.
We straightened the pin, carefully reconnected the wires, and everything worked just fine.
This says to us that the "E-2" error message means the console is missing at least one connection from the system. This could be caused by a bent pin, a torn/cut/frayed wire, etc -- anything that might make it lose signal.
So check the lower connection for bent pins, check the upper connection for bent pins, and check all along the wires for any kind of damage.
Hope this helps!
Posted on May 03, 2009
jexel
SOURCE: I have a 418 schwinn elliptical and the screen
hi there, did you get your problem solved? I am having the same problem and are searching everywhere without a satisfactory answer. hope you can help out!
Posted on Apr 30, 2011
My Nordic track elliptical audio strider 800 console does not work. I have changed batteries and I have purchased the adapter and still does not work. What can I do?
Better to buy a new console. It would be difficult to repair the existing console.
I'd you wish to get some details about elliptical repair then check the below added link.
http://electro-medical.blogspot.com/
Jul 20, 2016 | Nordic Track Exercise & Fitness
I receivd bh elliptical ocean program with no power cord.The sticker on trainer is torn,it has 6v but thats it. Googled & found nothing on Power cords or power sup needed to turn on thanx again,kirsti
It could be that the BH elliptical you have does not need an external power supply, but it does need a new set of batteries in the console.
For example:
The X8 BH elliptical is self powered, when a user strides at a speed about 20 RPM's; electricity is generated to allow the console to function properly. Exercising recharges the batteries in the console.
If you want to take a look at the X8's manual as a reference to see where the batteries are located in the console you can check it out here http://www.gophersport.com/files/pdf/GS68997_BHFitnessX81.pdf
We hope this helps in any way :) if you ever need a little help trying to figure things out you can chat with us at www.sportsmith.net or by phone at 888-713-2880
Apr 14, 2015 | Exercise & Fitness
My Proform 6.0 ZE elliptical is draining new batteries within hours and humming. It makes LOUD popping and static sounds when using the AC plug in.
DEAR
AT FIRST YOU COUNT YOUR BAT AND MULTIPLY 1.5 THEN YOU USE A ADAPTER AC TO DC WITH SAME VOLTAGE LIKE 6 V OR 9V DC
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
Mar 21, 2017 | Proform Pro Form 6.0 ZE Elliptical
No resistance for Healthrider H90E elliptical
More than likely your going to need a console...If you checked all the power from the console down to the resistance motor and that's good then console is bad.
Dec 08, 2013 | HEALTHRIDER H90E Elliptical Console Model...
Precor elliptical keypad replace
Step 1:
please see the video for help in dissasembly the elliptical keypad replace.
Step 2:
please SEE the detail for dissasembly the console in elliptical.God bless you
Console
Remove the bolts or screws securing the console to the upright assembly. Lift the console and confirm that the cable connections are secure. Remove the cover from the console's battery bay and install a fresh set of batteries. Replace the battery cover.
Detach the ends of the pedals from the crank axles. Remove the left and right disc shields and side shields. Inspect the interior of the base unit and locate the flywheel.
Inspect the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the flywheel until the magnet passes in front of the nearby reed switch. Loosen the screw securing the switch in place. Rotate the switch to reduce the gap between it and the magnet. Tighten the screw.
Replace the left and right disc shields and side shields. Reattach the ends of the pedals to the crank axles.
Jan 07, 2013 | Precor Efx 546 Version 1 Lower Body...
No led display is their a way to replace the battery or does it runs on batteries
There is a 9 volt battery in the back of the console. This small battery could be your problem. I am attaching a link to our Website for parts, as well as a link to the diagram for your machine.
Search Results
http://www.sportsmith.net/images/product_support/lifefitness/Crosstrainer/Consumer_CrossTrainers/Ct5500%20Rear%20Drive/CT55-0XXX-01%20SN100000%20Parts%20Diagram.pdf
Dec 23, 2012 | Life Fitness X5 Elliptical...
After replacing batteries on Proform PF800 console stays lit
Pull the batteries out let it reset itself while its doing that check all cable to make the connection are seated firmly then reinstall the batteries, unless the function pad is sending a phantom signal engaging the display to be on continuously,or by pure chance the upper electronics went hay wire
Apr 09, 2010 | Proform PFTL79807 - 850 W/ Gamefit...
Schwinn 430 Elliptical Trainer Logo
296 people viewed this question
Top Schwinn Exercise & Fitness Experts
Bill Boyd
David Kassin
David Kassin
Treadmill Repairs...
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
