Ovens Logo
A
Anonymous Posted on Aug 13, 2014
My oven is keep beeping and I can't cancel it
How do I cancel my self cleaning oven it's keep beeping and saying f1
  • Official Brand Answer 2,267 Answers
  • Posted on Aug 15, 2014
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1288913
Points
2557
Good Morning Friend, that's a great question!
Typically error code F10 indicates that your Frigidaire range has detected an issue with the runaway temperature (overheating). Let's attempt reprogramming your range by either unplugging it or flipping the household circuit breaker off. It is best to wait roughly ten minutes and then turn on your range. Usually this will clear most false error codes. If issue persists, at this moment I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps! - Z
5 Related Answers
Anonymous
  • 35 Answers
  • Posted on Jun 25, 2007
SOURCE: Oven keeps beeping and displaying F1
this code is suggesting that you might need a control board.
Anonymous
  • Posted on Nov 18, 2008
SOURCE: oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Anonymous
  • Posted on May 22, 2009
SOURCE: What does the error code F1 indicate, on a Wolf Oven?
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
Anonymous
  • 744 Answers
  • Posted on Aug 14, 2009
SOURCE: F1 is displayed on Maytag Electric Oven
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
tbirdfan1
Michael Thomas
  • 3056 Answers
  • Posted on Jan 12, 2010
SOURCE: f1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
How do I fix my oven door keeps locking up and F1 comes up and starts beeping
Here is a detailed description of this error code. Your control can be rebuilt by fixyourboard.com. See article here on Kenmore/GE F1 Error Code: Oven Failure After Self Clean and F1 Errors
Aug 27, 2015 • Ovens
1helpful
Fridgidaire self cleaning range: F1 error code?
You have a control board failure. First thing I would try is to unplug the range for at least 10 min. and then plug back in and see if that works. Hope that helps
1helpful
F1 ERROR
Hi. This (f-1) code represents a failed oven control board. Have this damaged board replaced asap, if possible. It has failed. Possible logic chip set failure.
4helpful
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
thank u
rate me!!!
1helpful
My self cleaning oven door will not open, and keeps beeping and
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$%^@#
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
2helpful
Frigidaire during cleaning F1 error,
F1 means its your electronic control and it will probably cost you the same amount to get this problem fixed again. The part is usually $350 plus.
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
