The led display is not.everything else works fine,would like to know how to fix it.
SOURCE: Bose lifestyle 12 music center display inop
My display has not been working for years. Replaced c17 cap wich was 33uF 63 volts on lower pcb board( only one on system) . Old cap was good so this was not the problem. Replaced c16 wich was 100uF 25 volts with a 100uF 63volts. Display works, old cap read low. Both c17, and c16 are located on the lower left hand corner of the larger pcb looking from the front of the unit. Hope this helps.
SOURCE: Bose Lifestyle 12 Music Center
I have had problems similar to this on many devices and it is usually a dud LED (light). You can technically de-solder the current LED and replace it but it's not a job for anybody without very good soldering skills.
Check to see if your system is still in warranty as this should be covered. Any electronics repair shop should be able to fix this for you.
Are you sure the red and white wires plugged into the audio output on your TV because I had the same problem and learned thats where you plug them into
