When brake is applied motor cuts off
It could be due to idling problems. See solutions in this video
Learn How to Fix Idling Issues on your Husqvarna Lawn Tractor
Also may need to make sure the carburetor and fuel filter are not dirty.
SOURCE: diagram of belt replacing on 21h 48 in cut husqvarna riding mower
You can try http://www.usa.husqvarna.com click on support and then product manuals. There you can find a diagram for your machine that could possibly help.
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
SOURCE: what kind of oil for a husqvarna riding mower?
Yes Briggs and Stratton recommends sae 30 in most all their engines even overhead valve (OHV)
Kohler uses 10w-30 in most of their overhead valve engines
Briggs has their own bottled oil with their label and additives and can find at lowes
Kohler the same
SOURCE: 2007 Husqvarna Riding mower blade will not engage
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Testimonial: "Thank you! That doesn't sound like an inexpensive solution. We appreciate your help, though."
SOURCE: Blades will not engage on Husqvarna riding mower.
I have a Husqvarna GTH2548 and the blades will not engage. It is free from all debrie
