Lexmark Prospect Pro205 Wireless All-In-One InkJet Printer Logo
A
Anonymous Posted on Aug 13, 2014
WHY AFTER CARTRIDGE HAS BEEN REFILLED AND REPLACED THE PRINTER SAYS CARTRIDGE MISSING
Dean Elbourn
Level 1:
New Friend:
  • Contributor 34 Answers
  • Posted on Aug 14, 2014
Dean Elbourn
Contributor
Level 1:
New Friend:
Answers
34
Questions
0
Helped
4963
Points
57
The trouble with most of the printer ink cartridge manufactures is that they have for a number of years made it harder to refill cartridges and want you to buy them new. It will depend on what model of printer as there are certain cartridges that can be refilled only for that model. Also what can affect your being able to refill cartridges is if your printer has had an update to it's own software, not the driver software.
5 Related Answers
Geraldine Watts
  • 390 Answers
  • Posted on Feb 12, 2008
SOURCE: black ink cartidge
If a black cartridge will not print, with no error messages, it is probably th printhead. Clean it with proper cleaning solution. Refilled ones if done yourself or by someone else, can also have air bubbles, Try blowing down refill hole with tissue under the cartridge to stop ink spills. Also, if you press a folder non scented wipe under the cartridge firmly, you should get a solid little black line or impression. This will tell you if the ink is getting down ok. Try reprinting.
don_farr
Don Farrell
  • 1018 Answers
  • Posted on May 09, 2009
SOURCE: refilled cartridge , printer says right cartridge incorrect
Lexmark builds intelligence into their cartridges and printers to prevent the use of refilled cartridges.
Lexmark has never approved the use of anyone else's ink for their printers primarily because there is no way to prove the quality of the ink.
Please purchase a Lexmark cartridge.
Anonymous
  • 18 Answers
  • Posted on Feb 25, 2010
SOURCE: refilled ink cartridge and printer tells me to replace cartridge
its impossible trust me,there is some kind of microswitch in the cartridge that tells the printer its empty-now then listen up-refill it before its empty and it will not know,hows that for a work around
PrintDocta
  • 217 Answers
  • Posted on Mar 30, 2010
SOURCE: Lexmark e120 not working after cartridge refill
Probably the chip on the cartridge that is either faulty, or hasn't been replaced
PrintDocta
  • 217 Answers
  • Posted on Apr 05, 2010
SOURCE: error 31 lexmark e350d
Possible causes here are;
Most likely, the contacts in the printer not touching the chip properly (hence why it works in another printer). A simple gentle 'tweak' would work in this case.
The other possibility is the firmware version of the (offendig) printer being incompatible with the version of the after-market chip you are using. No solution here, other than trying a DIFFERENT MAKE of chip.
Lexmark c524 eror black cartridge missing or empty
Re-install cartridge or if not original Lexmark cartridge, aftermarket refilled, the printer won't recognize the refilled cartridge.
7helpful
2answers
Lexmark S405 : printer will not print until the black ink cartridge is replaced
Smash printer with axe or sledgehammer. Grin maniacally. After researching on internet,go out & buy new printer that allows you to print till empty & refill again! Obviously not a Lexmark...
I just installed two refilled lexmark cartridges color and black yet printer is reading black cartridge missing and color cartridge missing. I am unable to print
Refilled cartridges become unreliable and can damage your printer - you will need to try an original Lexmark cartridge before considering replacing your printer.
1helpful
Tri colour problembought to refilled cartridges one displays problem other table, is it the refilled cartridges or the printerwrong cartridge 344 not compar
Hello!
When the printer tells you "wrong cartridge", it is because it cannot recognize the cartridge.
Remove the color cartridge and gently wipe the electric contacts on it with a dry cloth. Put the cartridge back in and check for error messages.
If the problem persists, you will need to buy a new color cartridge, because the one you have is damaged- one of the contacts on it has blown, and when you place it in the printer, it won't recognize it, because one of the contacts is missing (that is why some printers give a warning sign "cartridge missing").
Hope that helps!
I get a cartridge missing message in a Dell 810 printer
I am having the exact same problem. Just got my cartridge refilled, and whenever I hit the print command, I keep getting the message "printer cartridge missing." It's obviously there! gaahhh, so annoying! I hate dell.
2answers
Printer won't print-says color cartridge is missing and it is there
Just a shot in the dark, was it a refilled ink cartridge. I know HP has a problem detecting the remanufactured cartridges from time to time. And too, if it is not refilled cartridge perhaps you just have a bad cartridge.
Oh, of course Julie remembered to pull the tape off of the bottom of the ink cartridge, correct?
Hope this did some good, please leave rating,
thank you kindly.
1helpful
HP 4280 - new black refilled cartridge not recognised
hi steve... the solution to your problem is a costly one. the printer keeps in memory 2 cartidges for colour and 2 for black, when a third is placed in the printer the first one is deleted out of memory same for the colouredand same for the black... therefore you need 3 cartridges each to do the trick.
eg. if you want to use colour cartridge #2 then 1st place colour nuber 1 or 3, then turn it on let it reads, then open door and place in colour number 3 or 1 let it read, then take out and place in coulur number 2 and it will see it as new
2helpful
3answers
Refilled my Dell Ink Cartridge
It's never going to recognize a product that is not original even if it's refilled in the Dell cartridge. That's happened to me--you get used to it. Dell just wants you to get it from THEM and not from any where else. I have a 922 All-in-One....It's been good for the past 3 years.
I am trying to reset the empty ink cartridge error code on a Canon mp-530 multifunction printer after installing a refilled a refilled black ing cartridge
Hi, did you refill yourself or did you buy a refilled cartridge. If you purchased a refilled cartridge and the chip is missing, you will need to take the chip off your old cartridge and install on the refilled cartridge.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
