Cars & Trucks Logo
A
Anonymous Posted on Aug 13, 2014
Low beam headlight not working - Cars & Trucks
Brett Duxbury
Level 3:
  • Cars & Trucks Master 4,352 Answers
  • Posted on Aug 13, 2014
Brett Duxbury
Level 3:
Answers
4352
Questions
0
Helped
1120003
Points
13423
Check globe - Could be element blown on low beam part of globe. A lot of globes are haligon globes with two elements my low beam filament blew two weeks ago and I just replaced the globe but if you look at the globe you will see one of the two filaments is vapourised (missing) if blown.
5 Related Answers
A
Anonymous
  • Posted on Jul 16, 2008
SOURCE: low beam headlights do not work, but high beam headlights do
Clyde,
I've been troubleshooting this same problem on a different vehicle this week, and I can give you the steps I'd take.
1. If both sides went out at the same time, the problem is *NOT* likely to be the bulbs.
2. Check the fuses to see if both low beam lights are on the same fuse. Many cars have one fuse for low beam and another for high beam, so both lights out at the same time typically means fuse blown.
3. If the headlights are OK and the fuses are OK, then the problem is *LIKELY* the headlight switch. In my case, AutoZone has one and it can be installed easily; but in your case, that may not be as simple.
Please post your findings or comments.
Anonymous
  • 319 Answers
  • Posted on Mar 18, 2009
SOURCE: low beam headlights not working
check voltage at switch
Anonymous
  • 1986 Answers
  • Posted on Aug 12, 2009
SOURCE: Both low beam headlights stopped working at the
Could be the relay for the lowbeams is faulty, if your DRL's are your lowbeams, then your DRL Unit could be bad. Also did you blow a fuse cuz a random surge could blow the fuse
Anonymous
  • 7353 Answers
  • Posted on Dec 16, 2009
SOURCE: my passenger side low beam headlight is out. the
Check the fuse. There are seperate fuses for right and left. You dont mention if the high beam works for that side? If it does, the fuse is good. The GREEN wire at the bulb is the ground for the low beam. If that wire has power, then the ground is bad. If the high beam works, the hi'lo beam switch is good, and there is a problem between that headlight and the Engine Compartment Junction Block
Anonymous
  • Posted on Feb 15, 2011
SOURCE: 2002 Acura TL low beam headlight
How to Shift my headlight beam from position.
from I replace my headlight it's spatting directly on the ground..What can i do to change it from position
Driver side low and high beam on but dim. Passenger side low beam normal but high beam on and dim
I would check for the groundwire continuity
Driver side - dim low beams and no hi beam - Subaru Outback ...
www.subaruoutback.org > ... > General > Electrical & Electronics
Oct 11, 2014 - Hi everyone, My drivers side headlights are dim on low, (car has separate bulbs ... When the headlight switch is turned ON, but for low beams, ...
Driver-side Low beam Not Working (electrical issue not bulb ...
www.hummer4x4offroad.com/.../showthread.php?...Driver-side-Low-be...
Mar 12, 2015 - 10 posts - ‎4 authors
The high beam continues to work on both sides...I pulled the Driverside headlamp fuse and then both left and right beams lit up but very dim.
High beams ok, but not low beam - one side only - TDIClub Forums
forums.tdiclub.com > ... > VW MKIV-A4 TDIs (VE and PD)
Jan 23, 2014 - My driver's side lights are working fine - high and low beams. ... But it definitely looks like the big lamp on the driver's side gets brighter when ..... Drivers side headlight is very dim on low beam and goes out when on high beam ...
Dim driver's side headlight (low & high beam) - GrandAmGT.com Forum
www.grandamgt.com > ... > Technical Q&A
Dec 11, 2002 - 6 posts - ‎4 authors
2answers
Low beam lamp(s) fault detected 2014 kenworth no low beam lights
First check light relay fuse, if ok check battery voltage at low beam light terminal, if ok replace low beam bulb, if no voltage check switch side of relay, if voltage replace relay, if no voltage check headlight low beam switch.
No power to right side (PS) headlight low beam plug socket, new bulb, fuse is good. High beam works, blinker works, park light works. just no low beam and doesn't register any voltage on volt meter.
check low beam fuse when switched on if it has voltage registering across the fuse ,if there is voltage across the low beam RHS fuse then it is possibly a pinched wire from the headlight running back towards inside of the car
3answers
One low beam head lights will not work, high beam works though
check for a damaged wire for the low beam. Also wouldn't hurt to check the ground wire as the high beam will try and ground through the low beam but not visa verse
Lights will not turn on
HEADLIGHTS NOT WORKING
It can be faulty headlight switch or issue with its wiring. Or its faulty head light fuse.
To troubleshoot the issue i suggest you few help links with appropriate solution. So you can follow the test and confirm what exact problem is there in your case of headlights not working:-----
Click the link below: -----
All headlights not working?
http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
Working of Headlight switch?
Both headlight bulbs blow together?
Car headlight bulbs don't last long?
2007 Dodge Caliber: Low Beam Headlight Not working
http://technoanswers.blogspot.in/2012/06/2007-dodge-caliber-low-beam-headlight.html
2003 Toyota Camry: Headlights Work Intermittently?
http://technoanswers.blogspot.in/2012/04/2003-toyota-camry-headlights-work.html
Chevy Tahoe: Low Beam Lamps are not working?
http://technoanswers.blogspot.in/2012/04/chevy-tahoe-low-beam-lamps-are-not.html
2001 Chevrolet Tahoe: Headlights not coming ON?
http://technoanswers.blogspot.in/2012/04/2001-chevrolet-tahoe-headlights-not.html
2004 Dodge Ram: High Beam Light is DIM?
http://technoanswers.blogspot.in/2012/04/2004-dodge-ram-high-beam-light-is-dim.html
2001 Chevrolet Tahoe: Both Low Beam Lamps Not Working?
http://technoanswers.blogspot.in/2012/04/2001-chevrolet-tahoe-both-low-beam.html
Low beam headlights Modification?
http://schematicsdiagram.blogspot.in/2012/04/low-beam-headlights-modification.html
How to Replace a Headlight
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight.html
How to Replace a Headlight Bulb
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-bulb.html
How to Replace a Headlight Switch
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-switch.html
How to Replace a Headlight Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-assembly.html
How to Replace a Park Light Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-park-light-assembly.html
Headlight Assembly Removal On Honda Accord
http://technoanswers.blogspot.in/2012/06/headlight-assembly-removal-on-honda.html
Honda Headlight Assembly Removal
http://schematicsdiagram.blogspot.in/2012/06/honda-headlight-assembly-removal.html
How to Replace a Headlight Door
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-door.html
How to replace HID headlight bulbs for lexus 400h?
http://schematicsdiagram.blogspot.com/2012/01/how-to-replace-hid-headlight-bulbs-for.html
These will help.
Thanks.
2answers
Low beams dont work on 2000 volvo
It can be faulty low beam lamp or its connection issue for low beam lamps.
There are few solved helps links with proper solution to troubleshoot these issues.I suggest you to refer the links below.Click the link:----
Passenger side low beam out?
http://repairhelpcenter.blogspot.com/2012/01/passenger-side-low-beam-out.html
Low beam HID light goes out? http://schematicsdiagram.blogspot.com/2012/01/low-beam-hid-light-goes-out.html
----------2007 Dodge Caliber: Low Beam Headlight Not working http://technoanswers.blogspot.in/2012/06/2007-dodge-caliber-low-beam-headlight.html
-------------Chevy Tahoe: Low Beam Lamps are not working? http://technoanswers.blogspot.in/2012/04/chevy-tahoe-low-beam-lamps-are-not.html
----------2001 Chevrolet Tahoe: Both Low Beam Lamps Not Working? http://technoanswers.blogspot.in/2012/04/2001-chevrolet-tahoe-both-low-beam.html
--------------2002 Toyota Tacoma: Low Beams not working? http://technoanswers.blogspot.in/2012/04/2002-toyota-tacoma-low-beams-not.html
-----------Low beam headlights Modification? http://schematicsdiagram.blogspot.in/2012/04/low-beam-headlights-modification.html
-----------DRL and Low beams not working? http://schematicsdiagram.blogspot.in/2012/04/drl-and-low-beams-not-working.html
-----------These will help.Thanks.
1helpful
2answers
I have a 1995 Ford Explorer Limited and the high beams work but the low beams and fog lights do not, please help....
These trucks are known for bad multifuction switches.
the switch that i talk of is the signal switch , the handle is the switch, it bolts to side of steering column . this switch controls the signals and the headlights and high /low beams. the other thing is the headlight switch connector, the connector some times goes bad and starts to melt or just comes out of the connector. you will need to remove the cover to steering column, the screws are located under the bottom cover in holes. remove cover and check connector and then test for power if you have power going into switch but not coming out then switch is bad.
the last thing is to make sure the bulbs are good , make sure the headlight bulbs are good , and also the driving light bulbs, test for power at the connectors to those lights to.
You will need to do a little testing to find the problem.
Low Beam Drivers Side doesn't work ... low voltage,
Power for the headlights on the Left side (High and low beam.) comes from the same fuse... The ORANGE wire and the ORANGE/BLACK are the same, they connect in the harness. If you only lack the 12v to make the light work connect them at the headlight assembly.
If your low beam also lacks ground the Left low beam ground is shared with the right low beam ground... Run a wire from left low beam DARK BLUE to right low beam DARK BLUE/WHITE.
If its not working now then your cursed, seek a witch doctor.
1helpful
Low beam not work !!
replace the headlight bulbs. Usually when the bulbs blow out the low beam blows out first, but the high beams still work. If you want and need both low and high beams to work then replace the headlight bulbs with brand new ones and I garauntee that both low and high beams will work
Low beam headlights not working on 2004 Pontiac Montana extended
You headlight lamp have a diffuser mechanism which allows it to flip between the hight beam and low beam feature of the bulb. In fact, you high beam will function even if the low beam is not working.
I would recommend the purchase of the new headlight lamp. It would cost you you any where from $15.00 per unit to get a replacement lamp
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
