This problem happens once a month
SOURCE: The TV turns itself off
Hello.
You should check for dry joints on the inverter board.
Resolder them and see if it solves the problem.
SOURCE: sony 3 lcd rear projection tv hd w/ wega gate.
Hi, The
Standby/Power light of the TV blinks when there is any internal malfunction in
the TV. The self-diagnostic function of the TV will cause the STANDBY light to
blink or flash when the television detects an issue. The number of times the
STANDBY light flashes corresponds to a specific issue. Few
examples are given below; some of the issues may be resolved without the need
for service. If
the television is plugged into a power strip or surge protector, remove it from
the power strip or surge protector and plug it directly into the wall outlet.
If the issue is resolved, the problem is with the power strip or surge
protector and not the television. If
the issue continues to occur, service may be required. Thanks
for using Fixya.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a
power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your
set. The set will need to be serviced to allow a technician to determine the
specific issue that needs to be repaired. If the power light flashes three
times in sequence in a Lamp TV, the lamp cover is not securely attached.
Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power
problem.
6 blinks: - This indicates that there is some kind of audio problem with your
set.
7 blinks: - This indicates that there is a temperature problem with your set.
Please check to make sure that the air vents on the sides and back of the set
are not blocked or clogged and there is adequate ventilation around the
television. We recommend that you check and clean the vents periodically to
make sure the set receives adequate air flow. If the problem continues, the set
will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your
set. If the flash sequence is not listed above or the light continues to flash,
follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
SOURCE: sony bravia blinks 6 times
i have a Sony Bravia LCD TV KDL-60EX645
and it Blinks about 6 times every 25 seconds and it blinks next to the "Power" symbol? what does that mean? i cannot turn on the tv because it turns of and its not on eco and i just got it for christmas. its a 55" and i have a 3 year warrinty. but do i need to pay for it, or will it turn back on later ive been waiting about a week? i am a major gamer i usually spend 14-16 hours using the tv i am a youtuber, but does it burn out? i know alot about tv's but im not used to this error... i need some help so please contact me at [email protected]
Please help me. i might seem like a slacker but actually i make money of using the tv. thankyou for taking the time to read this and try to help me please. thankyou -Charles
SOURCE: sony kde37xs955 green light blinks 9 and red light blinks 6
how does a reset fix anything related to a LowB Error?
the symptom he described was: turn on, blinks green trying to get past self-check, then goes immediately into LowB Error.
reset won't do diddly
