Sony VAIO Notebook Logo
A
Anonymous Posted on Aug 12, 2014
Some letters don't work on my sony vaio
What is wrong , for no reason the letters stop working on my sony vaio
k24674
Level 3:
  • Sony Master 8,093 Answers
  • Posted on Aug 15, 2014
k24674
Sony Master
Level 3:
Answers
8093
Questions
0
Helped
4671847
Points
21595
Check the keyboard. If it is defective replace it. You might want to hook up a USB keyboard to ascertain that the laptop keyboard is the one that is defective.
5 Related Answers
Anonymous
  • Posted on Dec 18, 2008
SOURCE: Hot Keys
Follow this procedure to enable the special buttons or function keys on the computer or keyboard in the Microsoft® Windows® XP operating system.
IMPORTANT:
  • If software has been installed for use with a third-party keyboard or mouse, uninstall the software to ensure there are no conflicts.
  • On AMD™ or Transmeta™ processor-based computers, the function keys are hardware controlled and not controlled by a hot-key utility.
NOTES:
  • The volume button, brightness key, and disc eject button on some computers will not work if the HotKey Utility application is not running.
  • The Magnify button and the Fn keys will not function properly before the operating system has finished starting.
  • The setting may not be saved if the ESC key is used to close the Fn display. Press the ENTER key or allow the Fn display to close automatically to save the setting.
  1. Click the Start button, then click Run .
  2. In the Run window, next to Open , type MSCONFIG .
  3. Press the ENTER key.
  4. In the System Configuration Utility window, click the Startup tab.
  5. On the Startup tab, under Startup Item , ensure that there is a check in the HKserv checkbox. NOTE: If HKserv is missing, reinstall the HotKey Utility application and the Sony Utilities Library.
  6. Click the OK button.
  7. In the System Configuration box, click the restart button.
Anonymous
  • 17 Answers
  • Posted on Feb 12, 2009
SOURCE: Vaio keyboard not functioning
Sounds Like a Bad Keyboard
Anonymous
  • 37 Answers
  • Posted on Aug 21, 2009
SOURCE: SONY VAIO
Save Data if possible.
Use Restore System; Restore Computer to Factory "New" Condition.. Sont Vaios have a Key Prompt which you hold down while booting and the Replacement Software already on a Sector of the Hard Drive. Check THe Manuel for this OR CALL SONY CUSTOMER SERVICE AND JUST GIVE THEM THE MODEL NUMBER AND ASK THEM WHICH BUTTON YOU PUSH ETC TO RESTORE THE COMPUTER TO "FACTORY CONDITION"
Anonymous
  • 3 Answers
  • Posted on Sep 25, 2009
SOURCE: vaio care, vaio sat survey and vaio luncher have been stopped wor
I had the same problem , i was using a spanish date format.
I changed the date format to an english format (mm/dd/yyyy) and now all vaio programs work ok at start up and afterwards.
Anonymous
  • 154 Answers
  • Posted on Apr 09, 2010
SOURCE: my motion eye on my sony vaio stopped working but
you may reinstall the arc soft from here..
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNNS190JS&LOC=3
When i try to install windows xp on my sony vaio vgc-v2m the mouse stops working half way through the installation
Leave the installation finish as you don't need the mouse or anything else untill it complets.
This could take an hour or longer.
2helpful
Vaio care, vaio sat survey and vaio luncher have been stopped wor
2helpful
SONY VAIO
Keyoboard doesn't work/types wrong #'s and letters
IF YOU HAVE A OLD KEY BOARD LAYING AROUND SOMEWERE YOU CAN USE THAT
9helpful
6answers
Eject button on Vaio won't work
t seems like people are having problems with getting the Fn Brightness and CD Eject Keys working when installing XP.
The following files and install method works here:
01. Install SFEP [AR51] (Right Click - Install SonyNC.inf)
02. Install Sony Shared Library [AR51] and Restart when prompted
03. Install Sony Utilities DLL & Settings Utility Series [BX4]
04. Install VAIO Event Service. Select Custom and Check VESUnique and Sound [BX4]
05. Copy AR51 Vista VESConfig.ini (from attached zip file) to folder C:\Program Files\Sony\VAIO Event Service
06. Start - Run services.msc
07. Find Vaio Event Service in the Services list and Restart the Service.
Your Fn and EJECT Buttons should now work.
Tv turner not working in sony vaio VGN-AX570G
I have to ask this question, due to people posting in wrong categorys.
Is This A Sony-Vaio VGN-AX570G Laptop Computer, your struggling to find drivers for ?
All Vaios Come With Restore Disks. If you have these i,d suggest doing a system restore, whereby all of your original Vaio Software will be repaired-replaced on your hard-drive.
If you don,t have the Vaio Restore Disks, you can purchase on-E-bay for About £15.00.
No help on Vaios support Site For That Actual Model.
Mike @ Compurepair.
3answers
Sony VAIO PCV-W700G Desktop PC
I would fold the inbuilt keyboard back and use an external keyboard.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
