Question about Kitchen Appliances - Others
Pilot will not remain on Imperial deep fryer model ifs 40
    Habit-Forming:
  • 130 Answers
There are several possible causes of this problem, aside from a loose or damaged wire, which is uncommon. The cause in about 95% of the cases is a thermopile that has gone bad. The thermopile is the small cylinder that is attached to the pilot assembly where part of the pilot flame can contact it. It has a cable or wire going to the gas valve, high limit switch, or both. When hot enough, it produces and electrical current that keep the pilot on and allows the main gas valve to open. Be sure that you have a good pilot flame. The pilot may need to be cleaned or adjusted. The thermopile is not hard to replace in most gas fryers and not too expensive. This often starts as an intermittent problem. The second possible cause is a defective high limit. The high limit is a small rectangular device with wires going to the gas valve and a tiny stainless tube that goes through the bottom of the kettle to a sensor bulb, like the thermostat has. These are usually self resetting, but may have a small red reset button. If present check the reset. If no reset, jump the two wires and see if the fryer will now light. If so, the high limit is defective, assuming the fryer is not over temperature. If defective, replace. Do not operate the fryer in this condition as there is no over temperature protection. The next cause is if the oil is too hot, in which case the high limit will shut off both the main burner and the pilot. The pilot cannot be relit until the fryer cools down and the high limit resets. If the oil is too hot, usually over 425F, replace the thermostat. If the high limit trips when the oil is in the normal operating range, replace the high limit. The final cause is a bad gas valve. This is not too common, but the gas valve is expensive and a bit difficult to replace. Check all of the other causes first.
Posted on Sep 23, 2014
2 Suggested Answers
6ya staff
SOURCE:
SOURCE: Deep fryer catching on fire
From the video it appears many things could be wrong. The baffles and burner tubes could be clogged, the burner itself can be clogged, the flue is blocked, or this unit is using the wrong type of gas, ie: propane on a natural gas fryer.
Recommended steps for troubleshooting.
1. Verify proper gas type. Natural or Propane.
2. Check Burners, tubes, and baffles, clean all soot and debris from them.
3. Check for and remove any obstructions from the flue.
Posted on Apr 27, 2013
Pilot goes out after fryer reaches operating temp. Replaced milli-volt generator already.
sometimes the hole in the pilot tube gets dirty and needs cleaned in the old days the gas man had a tiny drill bit he reamed it with .
Mar 05, 2015 | Imperial IFS-40 - Gas Deep Fryer - 40 Lb -...
Where is the themopile on a imperial gas fryer efs-40
Right by the side of the pilot round shape and has long metal looking lead coming off it
May 13, 2012 | Imperial IFS40 Deep Fryer
The pilot will light but wont run when put in on position
Have you checked the output of the pilot generator ? Make sure you have a good strong flame on the generator. Sounds like you need a new pilot generator. takes 5 minutes to replace...cost around 40 bucks.
Tom
Jul 01, 2010 | Imperial IFS40 Deep Fryer
Brunners will not light on my imperial IFS-40
WTF your pilot light might be out RUN LIKE HELL- air the place out then go back and re-light it.
Aug 25, 2009 | Imperial IFS40 Deep Fryer
Pilot light won't stay lit.
Make sure the pilot has a shield around it. Also check for drafts in the area.
Aug 04, 2009 | Imperial IFS40 Deep Fryer
Ifs 40 deep fryer
I have a used fryer, imperial, looks like the ifs 40 but can not find the model number on it. Do you have any idea how I can find the model number?
May 13, 2009 | Imperial IFS40 Deep Fryer
Imperial fryer IFS-40
I had a very simular problem. My fryer would do exactly as you described, but sometimes the pilot light would stay on until the burners tried to re-ignite and then it would go out.
I finally had to call the gas company. They took the pilot light apart and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Oct 18, 2008 | Imperial IFS40 Deep Fryer
Imperial deep fryer model: IFS-40
Sounds like the pilot is dirty,if you have propane gas this is your issue,replace the pilot either way.
Aug 22, 2008 | Imperial Kitchen Appliances - Others
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
