Ortho Brush-B-Gone is quite effective, but it may harm other nearby plants, so take proper care. Make sure you follow the instructions on the container, and wear protective clothing. Do not apply on windy days, and it's best to check the weather forecast to make sure rain doesn't wash it off before 24 hours has passed. Once the plants are dead, again put on protective clothing, eye protection, and a heavy dust mask over your nose and mouth, so you won't become affected by the toxicity of the plants. Remove the plants and place in a large plastic bag. (do not burn them, it will spread the poisons through the air) Then dispose of them in a proper manner. When you're done, remove your protective clothing OUTSIDE, so you don't transfer the toxins to your furniture or carpeting in the house.
Bentonite has been prescribed as a bulk laxative, and it is also used as a base for many dermatologic formulas. Granular bentonite is being studied for use in battlefield wound dressings.
Bentoquatam is a bentonate-based topical medication intended to act as a shield against exposure to urushiol, the oil found in plants such as poison ivy or poison oak.
Bentonite can also be used as a desiccant due to its adsorption properties. Bentonite desiccants have been successfully used to protect pharmaceutical, nutraceutical and diagnostic products from moisture degradation and extend shelf life. In fact, in the most common package environments, Bentonite Desiccants offer a higher adsorption capacity than silica gel desiccants. Bentonite complies with the FDA for contact with food and drugs.
