It goes fast in reverse and slow forward but to go forward i have to push the reverse lever and to go in reverse i have to pus the forward lever i need to know what would cause that????
Sounds like the motor cables are in reverse at the controller. Check that the red is in the positive and the black wire is in the negative on the controller.
The wires that go to the throttle pot could be crossed over or the programing could have been changed. You need to either change the wires back around or get the programing looked at.
SOURCE: golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
