I am unable to print out the sheet with lines horizontally on Microsoft excel spreadsheet. How do I do this?
You have to turn on the border. Highlight cells that you want to add the lines to, Right click on the highlighted cells, and select "Format Cells" Then choose the boarder tab. To only do horizontal lines, simply click on the top and bottom lines. This will turn the borders on, and then they will print.
SOURCE: microsoft excel
This solution on average add 10 new worksheets in less than 5 sec.
Hold down shift key, then hit F11 as many time as many sheet you want to add
Other than SHIFT+F11, ALT+SHIFT+F1 also Insert a new worksheet, it's just to you which is more convenient.
Regards,
SOURCE: Printing problem with Microsoft Office for Mac 2008.
have you clear the set print area? if not go to File menu, select Print Area then select Clear Print Area
try also to set your sheet into page view to find out if you can view right page of your sheet.
try also to check your margin.
SOURCE: Excel Print Queue Delay Problem
It has to do with your collate settings on your printers properties and the collate settings on your first print screen that shows up when you go to print. First when you are ready to print select print from the file menu in excel then go to the properties of the printer you are going to use and make sure the finishing properties are set the way you want them. Hit ok then you will be back at the first print screen. Here uncheck the collate box and then print. I am unsure but this may work. I had a similar problem a while ago and I know if I played with the collate check box it would print much faster other wise each time it was going to print a copy of the document it had to resend all the information again to the printer, which took forever.
SOURCE: how to edit microsoft office viewer excel page without installing
You need XL viewer OR any software which can edit excel files. Search on google for the same.
SOURCE: I am having problems printing excel spreadsheets.
go to print with preview and select fit to media
