The Caiso DR220HD takes a
Universal 2-1/4" x 150' Calculator Paper Rolls
Calculator and adding machine paper rolls.
2-1/4" wide. 150' in length. 1-ply.
Your local office supply store shoudl carry this. or order online here:
Free Shipping On Casio DR 220 HD Paper Roll DR220HD
http://www.worldclassink.com/Casio-DR-220-HD-Paper-Roll-printer21507-ift198.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
SOURCE: Casio DR-250HD calculator
make sure you are in "print mode" step 1 pess the AC button step 2 press and hold for two seconds the % button step 3 press the tax+ button step 4 input tax rate step 5 press the % button now check to make sure that is correct.
SOURCE: casio DR-T220
Turns out the incorrect type of paper was being used. The paper needed is the paper that is sensitive to pressure and this paper was not.
SOURCE: HOW TO LOAD THERMAL PAPER IN DR-T120 CALCULATOR
Simply place the paper between the plastic posts. Put top portion down; feed paper up slightly - put smaller front plate back in place and press feed button.
SOURCE: HOW TO INSTALL PAPER ROLL IN CASIO HR-8TM
There is a slot just in front of the printer
1. turn the power on
2. turn the switch to "PRINT" position
3. slot the paper in & press "FEED"
4. the paper should be able to feed up
