How do I get the caller id lights to turn off>
Link to users quick reference guide.
http://service.us.panasonic.com/OPERMANPDF/KXT7720.pdf
SOURCE: Caller ID Light Won't Stop Blinking on Base of KX TC1713 Phone
Solved this myself simply by scrolling through all the Caller ID entries from recent calls . . .
SOURCE: Caller ID not working
I don't think the problem is the FSK vs. DTMF. The manual even states that the caller ID is generally received after the second ring. This is true in America. I lived in India for four months and I never ran into the problem there so... I just can't say how your provider sends the caller ID. It may be that the line is being interfered with. Do you have a DSL line attached to the same device. If so make sure that there is a filter between you phone and its connection.
I am assuming that you tested your line with the other equipment connected to the same location. You may want to reduce the problem to the simplest configuration by connecting directly to the line only no other equipment. If it works add the other equipment until the caller ID stops again. Then you know what is interfering. If you have a monitor set you could listen to the DTMF being sent make sure it is coming between the first and second ring. It is audible if it is there. If you are answering on the first ring you will not see caller ID you have to wait till after the second ring then you should see it, If BSNL is sending the same as American systems. Good luck Z
SOURCE: KX-TG6052 two handsets. Can't get Talking-Caller ID to turn off!
to turn the talking caller id off go to the menu press 0 then * then 4, then press 0 again to select off.
to turn the ringer on the handset back on, go to the menu, prees 1, 1, then press 1 for a low ringer, 2 for medium and 3 for high.
SOURCE: panasonic kxtd816 with caller id card kxtd-193 problem kxt-7431
All Panasonic display phones, both analog and digital 7xxx series phones support CID. It requires 5 or 6 program adjustments as outlined in the manual. With luck, you may be able to just turn it on in 406, but your area code needs to be set if you have 7 digit local dialing, you need to tell the system if you want CID to adjust the clock daily, SMDR display, etc.
The 1232_PG lists all the steps. If you don't have a manual, you really need to get one. Post back and we'll see what we can do.
Carl
SOURCE: How do you turn on caller ID on a Panasonic KX TGA181AL
Is your phone operated off a panasonic system? is so you need a caller id card. if not then you would need to inform your phone service provider that you need caller id. if you have caller id and you do have the caller id card you would need to get a hold of a panasonic tech who could turn on your c.id as long as it is being provided from your phone service and the card is installed.
