Before replacing these bits, I would need to know if something has caused them to melt and if it is likely to happen again
Hi
These are the valves If they are melted this is because the washer is being left running without being triggered. I also suspect yoru unloader may be failing...your will want your unloader tested. The only way to test anything is to replace these valves first. unfortunately I would also inspect your packings as well as the pistons. when water builds up for a length of time without triggering the washer it recycles and builds up heat....this heat starts to melt your valves....this can also happen by starving your pump for water....running it without water....or by a failed unloader where it doesnt allow water to bypass...do you have to pull the trigger of your wand to start it? If so then your unloader needs work. If it has been starved for water..then your packings will show that damage as well...Usually the farthest set from the inlet having the most damage. Also, when that all get hot as soon as you trigger it and cold water is introduced into the pump, this "shocks" the pump packings and pistons. You want to check the pistons to see if they have cracked..So inspect your pump oil for water...look to see if its white-ish looking... Check your pistons for cracks...check your packings for wear. If you see wear that increasingly gets worse the farther away from your pump inlet then thats a tell tale sign of starvation. ..if your pistons are cracked you will need to replace packings as well anyway. Then replace your valves...reassemble and test your unloader. Good luck to you man. You can get all parts here Pressure washer parts catalog quick links Pressure Washers High Pressure... or FIND PARTS FAST
SOURCE: I just bought a replacement pump today. Model
The oil will be in the stainless steel or silver colored part of the pump. If there is no access to this part then the oil is put in there by the manufacturer. I believe the small red plastic plug you speak of covers the overheat blow off valve. Just leave it. When you run the washer for a long time you may see some water spill out of there. The only way to change the oil is to separate the two pump sections. Not advisable without some knowledge and the correct tools
SOURCE: i have excell 3700 pressure washer...the pump
This is probably the ZR3700-1 with the General pump...this is not a good pump and I woud suggest replacing the pump with either an Ar pump or a Cat pump.
The complete AR pump paet number KIT-MSI is probably the way to go.
You can find that at www.msservice.net as a complete kit for less than anyplace else. The CAT pump woulb be about $800.00
SOURCE: My DPD 3100 is leaking from a brass fitting on the
first things first, before replacing I would wrap this valve with teflon tape and then retighten and see if the leak stops, I checked the entire schematic and found no listing for a spring so this is part of a valve assembly of some type. It might be the unloader or the thermal valve so if there is any doubt about getting the right pressure on the cap I would replace the valve to ensure safety. the valves I saw are less than 25.00 so for the price I personally would replace. check the surrounding area for cracks also. Now as where to buy parts, you can go to Dewaltservicenet.com and download a parts breakdown of the pump assembly and also other areas for this washer. You can also buy the parts online from them. Let me know if you need more assistance
