Cleaned it yesterday so could it be water on electrics? I am afraid to use it. Book does not show how to get into light fitting to check. What do I do?
SOURCE: There is an unpleasant smell (like rotten
Unfortunately the fault can be that there is some organic matter that seems to cause the issue , it can be sometimes insect or small creatures that have caught into the magnetron high voltage and is cooked.Also it can be insulation failure on the magnetron that causes the smell on heating of the material. In all these cases the oven must be opened out- taken out and observed.
If the fault is in the magnetron, or the capacitor that is leaking or an insulation of the transformer, then it must be replaced. But in the first place check if you can remove the unit with your resources.
If there is spark please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is leaking and sparking to the ground. As you have mentioned it was stored, it is quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Now switch the microwave power on and use a cup of water to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. Replace with same type. If not check the waveguides within the cabin for food particles that can burn and spark, check for rust that can corrode and spark when the ceramic paint has worn out.
If there is heating without any issues, you can use the microwave safely
The flashing can be sparking of the magnetron please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is leaking and sparking to the ground. If this was stored, it is quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
Now keeping clear switch on , use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues , you can use the microwave safely
