Can not find how to se up message for incoming calls [email protected] or my cellphone 682 351 3758 message for my home phone Model CL 2909
SOURCE: Be able to pick up incoming calls from all front office phone sta
Get a copy of the manual here
http://www.cactcom.com/Manuals/Vodavi/Vodavi%20DHS/Vodavi%20Starplus%20DHS%20Installation%20And%20Maint%201995.PDF
Looks like you can group the stations together and then any one of them can answer incoming calls. See page 45 or so.
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
SOURCE: we just installed ATT-uverse & our incoming calls don't work
I have the same issue with incoming call not displaying (call waiting). Contacted ATT Unverse customer service and was advise this is a technical issue at their end and no resolution before year end. I was not a happy camper to learn this and was not informed up front when service was installed.
SOURCE: cl and 0 flashing
Your time needs set on your answering machine. If you have buttons on the top of your base, press and hold the day/check button to set the day of the week. Press and hold the hour button to set the hour. Press and hold the min button to set the min. If you don't have buttons on base, press flash button on handset to enter answerer remote mode. Press the 8 key to enter time set menu. Set hour and min using number buttons and set am/pm using caller id buttons. Press # pause to confirm the setting.
