Black & Decker String Trimmer Cordless 12" 18V Logo
A
Anonymous Posted on Aug 12, 2014
Black decker diagram cst1100
How does the safety guard attach on a CST1100 Black and Decker rechargeable trimmer to the trimmer head?
5 Related Answers
Anonymous
  • Posted on Apr 24, 2008
SOURCE: CST1000 Black & Decker Cordless Trimmer/Edge won't start
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/blackdecker/CST2000_TYPE_1
Part number #243614-00.
It's a microswitch made by Honeywell that costs about 5 bucks plus shipping.
The attached file has the schematic and parts list.
The CST2000 is well worth spending a few bucks to keep it going. Finding a local B&D authorized service center near you will even save you the shipping as they can order it for you.
Every other component is pretty dependable- the motor, battery, wiring, charging system, spool system- all built to last.
Only down side is you really only get 20 to 25 minutes of hard weedwhacking before you need to recharge. Of course, it's time for a cold beer in the pool by then.
A
Anonymous
  • Posted on May 10, 2008
SOURCE: changing spool on weed trimmer
useless
Anonymous
  • 313 Answers
  • Posted on Jul 28, 2008
SOURCE: black and decker grasshog trimmer line feed problem
email [email protected] or see www.dewaltservicenet.com look for the find it now icon & enter the model #
Anonymous
  • 183 Answers
  • Posted on Apr 28, 2009
SOURCE: auto feed will not work
It's cheapest to buy a new one. I had that problem last year.
Anonymous
  • Posted on Jun 29, 2009
SOURCE: Black & Decker 8209 Weed Trimmer
I went to the B&D web site and downloaded the manual for this unit.
Here is the link
http://www.blackanddeckerservicenet.com/Products/ProductManual.aspx?q=8209
VEC157BDC Spotlight
remove the black rubber guard from the front there is a screw on each side remove them then remove the lens guard then you can get to the bulb. I hope this helps. You will need a phillips screw driver and a flat head one small ones
My Black and decker cordless trimmer is not quite out of juice but it is not cutting anymore. can i recharge it now or do i have to wait until the battery is completely dead?
You can recharge the battery at any time. I usuly use mine then when done using it I put it back on the charger so I know it will be charged the next time I need it.
CST2000 can't get the battery off when pushing the two release buttons.
Black & Decker didn't make it easy to remove the battery pack. You have to push both buttons in at the same time, while pushing the battery pack forward. It takes a little while to get good at it -- you have to hold onto the trimmer with the same hand that's pushing the buttons in, while pushing the head forward with the other hand.
If you're only taking the head off to charge the battery, you can charge it while it's still attached. The hole for the adapter is on the back of the head, so you can plug it in while it's attached to the trimmer.
Hope that helps!
I have a Black & Decker electric trimmer. Do I change the guard around or leave it where it is to do trimming? It is on the bottom--should it be on the top and how do I switch it?
You are talking about a string tirmmer, right? Leave the guard where it is; it's there to protect your feet and legs from getting hit with twigs, rocks...anything the trimmer might kick up.
If you are using it as an edger you can keep the guard where it is, just flip the trimmer to do the edging.
4helpful
3answers
Top Black & Decker Garden Experts
Thomas Perkins
Thomas Perkins
Mike Cairns
Mike Cairns
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
