Apple iPod shuffle MP3 Player Logo
A
Anonymous Posted on Aug 11, 2014
Ipod instruction manual
HOW TO SWITCH PLAYLISTS
3answers
How do i delete all my songs on my ipod?
Hi inthebag pik...
Try this easy way to delete your unwanted songs...
Deleting Files,Pictures,Videos,Audio Books, Apps,etc. from MP3 Player/Ipod
BIG WARNING: DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
ONE MORE BIG WARNING: BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Please take time to rate me thumbs up
2helpful
How do i upload songs
How to Upload Songs to an iPod: (You can also find the instructions here.)
1)Download the latest version of iTunes. It is free and you can obtain it from the Apple website. It could have come with your iPod on an installation CD. Makes sure your computer meets the requirements. You can find older versions on the web, but they have limitations.
2)Scan your computer for songs to add to the library.
3)Connect your iPod to your computer with the USB cable that came with your iPod. The iPod screen should say "Do not disconnect".
4)Open iTunes. Your iPod should appear under Devices in the bar to the left.
5)Follow the instructions for naming your iPod and changing the initial settings if the iPod has not been plugged into a computer before.
6)Buy music from the iTunes music store or import songs off a CD using iTunes.
7)Decide whether you want to sync your iPod with your iTunes library or manually put songs on your iPod.
(Syncing your iPod will automatically add all of the songs in your library to your iPod. It will also delete any songs from your iPod that are not in your library. Click on your iPod icon and select Sync in the lower right corner.)
8)If you do not want all the songs in your library on your iPod, make a playlist of all the songs you do want, or decide which playlists you want to include on your iPod.
9)Click on your iPod icon.
10)On the top bar, click on the button which says "Music".
11)Make sure the box that says "Sync Music" is checked, then check the box for whether you want your iPod to sync with the entire library or selected playlists. If you click selected playlists, select the playlists you want in the playlists category. For newer iPods you can check which artists are included on your iPod to automatically import all the songs from each selected artist onto your iPod.
12)Properly disconnect your iPod using the eject button (see Warnings).
13)Listen to your new songs!
TIPS:
Set up the iPod on the computer you plan to use it on. An iPod set up with a Macintosh will need to have all the songs deleted in order to use it on a Windows operating system. This only needs to be done once if you switch computers, but just to make less hassle, try to use the iPod on only one computer.
WARNINGS:
Make sure you disconnect the iPod properly to avoid problems or loss of files on your iPod. Click the eject button next to the iPod icon in iTunes, or in the lower, right-hand corner. If you quit iTunes, drag the iPod icon on your desktop to the trash to eject (Mac). Right click on the iPod icon on your desktop on a Windows PC.
Things You'll Need:
- USB connector cable
- iTunes
- iPod
- Computer
- Music files or CD's
Hope this information helps!
1helpful
2answers
Load music on my ipod
Decide whether you want to sync your iPod with your iTunes library or manually put songs on your iPod.(nano only)
2answers
How to make playlists on ipod?
select a song and hold the centre button until the title flashes. Then choose the other sings you want to add then choose music then playlists and then On-The-Go to view your song list then save playlist to save the list. Hope this helps
1helpful
Need instructions to add music from pc to ipod nano 4gb
get itunes and install that and you should then be able to add music that way ( depending on if you have it enabled to manually manage music in which case you can drag and drop music onto your ipod or playlists or if you dont then you have to click on the ipod and go to teh music tab and click on the playlists you want to synch with your ipod )
There is another piece of software you can use instead of itunes if you dont like itunes and I will post that here in a bit
If you need clarification or are stuck post back and let me know
1helpful
2answers
Download iTunes from Acer notebook to iPod nano 8gb
iPod offers three ways to transfer music from your computer. You can select one of the following update modes from the iPod Preferences menu in iTunes:
1. Automatically update all songs and playlists. This is the default mode, in which your entire music library, including playlists, is automatically synched to your iPod. If the music library on your computer exceeds the iPod storage capacity, iTunes will offer to choose a selection of songs to sync to iPod.
2. Automatically update selected playlists. With this option, iTunes automatically copies only the playlists you have selected to iPod when you connect it to the computer. This option can be selected by accessing the Music tab of the iPod settings.
3. Manually manage music. You can also choose to transfer music to iPod manually. This allows you to drag and drop individual songs and playlists from iTunes to iPod. You can find this option by accessing the Summmary tab of the iPod settings.
CANNOT WATCH iPOD mUSIC vIDEO on Panasonic SC-PT865
Maybe because is only read audio, like Photos and mp3 audio only, expecially if read format llike "High Mat" to read photos and music, try to go to instructions manual and see the format what your dvd read.
2answers
IPod and system recovery
If you switch to manual it might be easyer to manage the music.
4answers
How to download
If you are asking how to add songs to you iPod
(assuming you want to use iTunes)
Sync your iPod with iTunes
  1. Connect your iPod to your computer.
  2. When the iPod icon appears in the iTunes window (below Devices), select it.
  3. If the Summary pane isn't showing, click the Summary tab.
  4. To automatically sync your iPod:
    1. Make sure that "Manually manage music" is not selected.
    2. Click the Music tab and do one of the following:
    3. To automatically update your iPod with all the songs and playlists in your library, select "Sync music" and then select "All songs and playlists." iTunes loads the songs and playlists in your iTunes library onto your iPod, and deletes songs from your iPod that aren't in your library.
    4. To automatically update your iPod with only certain playlists, select "Sync music" and "Selected playlists," and then select the playlists you want synchronized.
  5. To manually sync your iPod:
    1. Make sure that "Manually manage music" is selected.
    2. Click Music (below Library, on the left side of the iTunes window) and then drag songs and playlists to your iPod.
Two ipod products on one pc
Hello there! There are a few different ways you might solve this problem. The easiest thing to do would be for you and your husband to each create your own playlists. Consider putting your initials in front of the name of each of your playlists, and your husbands initials in front of his, so that in an alphabetical list, you wind up with all of yours grouped together, and he has all of his grouped together. Now it's time to connect each iPod in turn. When you connect yours, click the iPod icon in the left hand column (the 'sources' column), and click through the tabs to the right until you get to the screen where you can choose to sync 'all playlists' or 'selected playlists'. Click on 'selected playlists' and then check off all of yours (or whichever you'd like at the time, if you have more music than will fit), none of his. When your iPod is done loading up that music, go ahead & disconnect it. Now repeat the process for your husband's iPod, selecting his playlists but not yours. From that point forward, when you plug in each iPod to sync with your library of music, it will remember which playlists it is supposed to sync with, and which it should ignore. Just remember that if & when you create brand new playlists in the future, you'll need to go back into the iPod settings to tell iTunes to sync that new playlist with your iPod (this can be done only while your iPod is connected). Hope this gets you where you were looking to go... best of luck!
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
