SOURCE: Looking for User Manual Nikon coolpix P90 camera
Hi Ravi.
You can download a non-printable copy of the manual here.
To print the manual you will have to provide the model number.
If you want a printable copy of the manual start from here, entering the model number on the page linked to printable copy
Regards.
SOURCE: Looking for a PDF Manual fo this camera
http://www.nikonusa.com/Assets/Digital-Camera/26171-COOLPIX-P90/PDF/P90_brochure.pdf
dont forget to say thanks ;)
SOURCE: I HAVE A NIKON COOLPIX P90,HOW DO I TRANSFER
Do you have the usb cable that came with the camera? If so plug that into your computer and your computer should them recognize it and give you instructions. After your files are saved to your computer add them as an attachment to your email and send.
SOURCE: My Nikon COOLPIX S51 Will not turn on.
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
SOURCE: i need a manual for
You can get the manual on the link below.
http://www.nikonusa.com/pdf/manuals/noprint/P90ENnoprint.pdf
Good Luck and please rate 4 thumbs up for the free answer
Testimonial: "thank you for the quick and great help"
