Sony Network Walkman NWZ-S545 Digital Media Player Logo
A
Anonymous Posted on Jul 28, 2017
I have a sony walkman nwz-s545 and when I insert it into the sony docking station srs-nwgu50 or my other docking station icf-c8wm, the mp3 player will not charge, but it will charge with the usb cord plug in and I am befuddled as why, I originally thought it was a connection issue then maybe a battery issue but now I am really not sure, any help would be widely appreciated, thank you.
5 Related Answers
Anonymous
  • Posted on May 29, 2009
SOURCE: mp3 will not connect with my computer
I'm pretty sure I fixed a similar problem. Go to your device manager on your PC and uninstall the walkman driver. After this is complete just plug the walkman back into you Pc and the plug and play will download the driver again. This worked for me. My operating system is Windows vista.
Anonymous
  • 5 Answers
  • Posted on Jun 02, 2009
I had the same problem. Don't buy a new cord. There is a sony place in winnipeg you can get it fixed there.
Anonymous
  • Posted on Jun 04, 2009
SOURCE: how do i make my mp3 connect with my computer
I had the same problem. I had not had any problems for months and suddenly it wouldn't connect. I got on live chat w/ Sony (3 times) and finally got someone who seemed to know what they were doing. I have a Sony computer and they had to send me a link for a USB "patch". After downloading it, it fixed it.
Anonymous
  • Posted on Sep 14, 2009
SOURCE: Sony Walkman NWZ-S618F MP3 Player - Screen display not working
I Have the same problem, but mine has vertical lines running on the display, try contacting sony support
Anonymous
  • Posted on Jan 11, 2010
SOURCE: Sony MP3 player not recognized by Vista after Norton 360 added
Unscrew it and open the player. Cut all the wires. Then by the 24k gold wires at candian tire or home hardware. They are cheap. They cost about $10, 000 each roll.Then connect every thing back together and screw back together. Then plug USB to your player and the computer. Then the computer should read it. If not, then open Windows Media Player. It should show up on that. Still if not, then download the software Trojan Virus v.11. Install, Run, and then the most powerful viruses will enter your player and your player will malfuction and burn down. You might think, THATS EVEN WORSE! Dont worry,we still got a few steps left. Then go to your kitchen and start the fire on your stove. Go ahead and drop your player in the fire. Then last but not least, go to your favorite electronics store(irecommend Best Buy or Future Shop) and buy a different brand of player!(i recommend Apple iPods or Zunes) Hope this works! Thanks!
Did you know?
Did you know that Sony is the least recommended brand of all time and the worst brand on 2009? Hope it improves this year!
Need a manual to operate the player
You will find everything you need for your NWZ-S545 (operating  guide, operating instructions and quick start guide here:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=NWZS545
2answers
Bought a sony mp3 s545 in the UK. Volume is extremely low. Anyway to bypass this?
Go onto your menu and down to audio options. Normally there is a cap on the volume they put on the manufacturing settings. In Audio options, there is another setting for volume normally called general audio or something similar. Raise up the volume cap. There you have it.
How to unlock the volume limit in Sony Walkman NWZ-s545
I'm just wondering, why don't you just download the MP3Gain. You can adjust the volume of all the songs to one db of your choosing. It's easier than trying to set up your mp3 player using the test mode, the result of which is usually the radio malfunction.
1helpful
How can I change the background in SONY NWZ-S545
Hi snake 131,
I'm afraid you probably can't. I have one of these things, only one year older, but I have not yet found anything to do with changing appearances or color. I'm afraid it is stuck that way, but you can still check online at http://www.sony-asia.com/support/product/nwz-s545.
Its dead. there is no power at all, even when I plugged it into my PC. Sony Walkman NWZ-S545
Hi konektor1,
Is it on hold? Check that first. If that is okay, and you still have it within the warranty period, get it checked for battery problems.
My sony walkman won't turn on
Thank You DamonJones. Hitting reset on the back with a pin WORKED. My mp3 is back up and running with all songs
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
