Brother HL-2040 Laser Printer Logo
A
Anonymous Posted on Aug 11, 2014
How do i stop print on brother hl2040
The printer was told 251 copies when i only wanted 25. how do i cancel the print?
  • Troy Staley
    Troy Staley Jan 13, 2018
    go to devices and printers when you click on the windows logo. rt click on the printer and a menu will open. one selection will be to cancel documents..
Kevin.
Level 2:
Sergeant:
  • Expert 256 Answers
  • Posted on Jan 13, 2018
Kevin.
Expert
Level 2:
Sergeant:
Answers
256
Questions
0
Helped
75458
Points
517
Right click with mouse on the print icon in bottom right of pc ,select cancel print in list, then go to printers in control panel and clear all print jobs in your printer list.
5 Related Answers
MUKHTAR
mukhtar21 shaikh
  • 2022 Answers
  • Posted on Oct 06, 2007
SOURCE: Brother mcf7220 will not print..says "cancel printing" "job cancel"
firest you swithc off all the printers and wait for some minute then clear all printers queue by going in to printer folder then restart your system.
Anonymous
  • Posted on Nov 25, 2007
SOURCE: brother mfc 8440 "printing" problems
Hi
I recently had this problem - tested fuser and all sensors.
The fix is to reset the memory.
To do this, enter the Maintenance mode. Menu, * 2864
(enter the number quickly)
then type 01 ( zero one ), this will reset all memory including the user settings.
Finally type 99 to exit Maintenance mode.
The printer will restart and the error will be gone. Test out with copy and printer reports
Hoping this fixes your problem
Regards
Lindsay
Anonymous
  • 26 Answers
  • Posted on Dec 15, 2007
SOURCE: Brother MFC-420CN color ink empty but want to print/copy in B&W
brother won't print od do anything is one of the 4 inks are empty so first of all you have to replace whatever is empty, when you remove it it will ask you if you changed it and if it is a new one you will press 1 twice per cartridge, if you put compatible ink in you will clog the ink head up and then be stuffed
Anonymous
  • 832 Answers
  • Posted on Jan 10, 2008
SOURCE: Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Anonymous
  • 41 Answers
  • Posted on Jun 25, 2009
SOURCE: brother hl 2025 tn will not stop printing
You have the wrong drivers or corrupt drivers on your system.Disconnect your printer and restart.uninstall your printer and download new drivers and reinstall.all should be fine
How to stop and cancel printing on brother Hl-2240d printer on a Mac Pro computer
Most printers can be stopped by going to your control panel and selecting printer and then find the command that cancels the printing job. Try this teaching video:
https://www.youtube.com/watch?v=YXIM_17IIl0
Brother All in one printer screen is stuck on "telephone"
Press the Stop Button to cancel whatever you are doing on it. Then press Copy to be able to copy.
If you are printing to it from a computer it should just automatically get to printing when it is sent information.
CAN I MAKE A COPY WITH THE HL2040. IF SO, HOW? THANKS
No this unit is only a printer
How ever if you have a scanner you can scan the original and print it on the printer
2answers
It used to work fine but now the HL2040 will only print one copy even when I select multiple copies on the control-P menu on Microsoft Word 2007. I've done all the Brother software and firmware downloads.
my friend has one and you will have to go to the fax mode and then switch it on again and change the number from 1 to 10
this should do it
if not you may have a problem with switch
Brother MFC-8440 will not print or copy
YOU HAVE TO RESET.
TURN OFF THEN PRESS THE STOP /CLEAR BUTTOM THEN TURN ON KEEP PRESS ABOUT 10 SECOND THEN IT WORK .
Partial logo printed on Brother HL2040
This appears to be a duplicate posting, click on this link to view the active posting: http://www.fixya.com/support/t135964-brother_hl_2040_printing_problem
Norman Weimar
Norman Weimar
k24674
