Computers & Internet Logo
A
Anonymous Posted on Aug 11, 2014
Ibm thinkcentre 8183 drivers
Ethernet controller drivers
cliff cook
Level 2:
Scholar:
New Friend:
  • Expert 144 Answers
  • Posted on Aug 24, 2014
 cliff cook
Expert
Level 2:
Scholar:
New Friend:
Answers
144
Questions
0
Helped
37238
Points
252
Hi
You should be able to download them from the support section of IBM's web site
Cliff
5 Related Answers
Anonymous
  • 2351 Answers
  • Posted on Jan 30, 2008
SOURCE: Ethernet, Multimedia, Video Controller is not recognized
IBM has the worst site I have seen so far for driver downloads. I have posted a link for you to go to IBM. You'll have to go through the downloads & find what you need. Like Lan drivers, audio drivers, video & so forth. You may find a restore CD download. You do not want to install the restore CD. Just pull the drivers off of it. http://www.ibm.com/search/?v=14&en=utf&lang=en&cc=us&hpp=10&catx=Y1zkzPz66zazbAzNA&q=ThinkCentre+A50p&cp=top&lv=c&cat=P9&x=10&y=10
Good luck, this will take some time but should also work for you!
Please vote...
Anonymous
  • 564 Answers
  • Posted on Feb 21, 2009
SOURCE: i want network driver for IBM Thinkcentre please
http://www-307.ibm.com/pc/support/site.wss/TCTR-MATRIX.html
Here is what you need. Just click the Link Above and select your model. Please Rate My Response! Thanks!
PREM
computerscot
  • 166 Answers
  • Posted on Apr 14, 2009
SOURCE: IBM ThinkCentre 8183 (M51) does not boot
The situation you describe is usually 1 of 2 things, Power supply (PSU) or Motherboard (mobo).
Situation #1: If you get a blank screen and no sounds or movement it either indicates that the power supply unit (PSU) has failed or something on the motherboard has failed, preventing normal startup. Fans are usually the first thing to get power, then the mobo for the Power on Self Test (POST).
Situation #2: You might get some power lights coming on and some fans spinning but the video output does not happen and normal startup sounds do not take place, usually indicates that motherboard is going out or has gone out. OR it may be due to a weak (damaged) PSU.
Always try a different power outlet that you know is working. (Eliminate the easy stuff first!)
If it is out of warranty, try opening up the case, with the power off, of course. Also take this time to inspect the capacitors on the motherboard (they look like tiny soda cans) and check for tops that are bulging, swelling or leaking anything. Capacitors should be perfectly flat on top. If you find these then your motherboard is bad (well technically the capacitors on your motherboard are bad). The bad caps will need replacing to fix (not a job for an amateur). If it passes the visual inspection then it may just be your power supply is bad. Notice that a bad PSU does not mean you are getting no power, just not enough to start and run the computer.
A few years ago a company stole the recipe for making capacitors and started making their own capacitors at really cheap prices. The stolen "recipe" was not complete and not correct so these caps started failing after about 2-3 years of use. Emachines, DELL and Gateway were the computer companies most affected by the bad capacitor issues, although any of the big companies could have the same problem. These bad caps also affected power supply makers.
Since you have tried removing components then it looks like you have narrowed it down to either the power supply or motherboard. If your motherboard looks ok and if you can get another power supply that has an output watts that is greater or equal to the one that you have, try replacing that first.
Anonymous
  • Posted on Dec 07, 2009
SOURCE: ethernet drivers ibm 8187 thinkcentre m50
No, this is a SCAM advert. Driver Detective is a con. They are charging you for a FREE driver available on the net. CON CON CON!!!!
Anonymous
  • 327 Answers
  • Posted on Jan 12, 2011
SOURCE: Windows 7 i need audio
OK. download it from this link:
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
please Vote
Ethernet controller
You don't mention your OS, so I have chosen a link that gives you the option of choosing your OS and also the type of ethernet controller you have in your particular system. If you don't know and can't find out which is yours, you may have to download several and try them in turn to see which works. The link is:-
http://www.driversforfree.com/omn_ofm_omd_dt/ibm/thinkcentre-s50/8183/network/drivers.aspx
Good luck.
Ethernet drivers
this is the official site which allows you to download ethernet drivers for this model.
intel ethernet drivers and applications thinkcentre a30 a50 a50p m50 m50e...
7helpful
Ibm mt-m 8183 ethernet drivers
I WANT TO INSTALL IBM MT-M 8183 QRG AUDIO DRIVERS FOR WINDOWS XP PROFESSIONAL
2helpful
2helpful
All driver down lode
http://www.reviversoft.com/computer-drivers/IBM/ThinkCentre-S50/8183/Download-Latest-Driver-Updates.php
here you will find your driver!
With kind regards,
MisterN
Please help to locate free Audio Driver for my IBM Thinkcentre S50 model 8183 WR4 having operating system Windows7 Enterprise - 32 bit.
There are no official drivers for your hardware on the Lenovo website. Your hardware might not be supported on Windows 7.
When i installed xp on my ibm thinkcentre i discovered that my sound is not working, i have no vga compatible and ethernet controller. please how can i solve this? i am using ibm thinkcentre intel(r)...
The drivers are available from Lenovo incl a BIOS update for the model ThinkCentre M50 8189-F6G:
support.lenovo.com/en_US/research/hints-or-tips/detail.page?&LegacyDocID=MIGR-50534
2helpful
2answers
When reinstalling windows xp, I had to activate windows. Well I am now not connected to the internet.It seems I am missing "ethernet controller","multimedia audio controller","sm...
You can download the missing drivers from here:
http://www-307.ibm.com/pc/support/site.wss/product.do?template=/product.do?template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&sitestyle=lenovo&brandind=11&familyind=121125&machineind=121227&modelind=0&partnumberind=0&subcategoryind=0&doctypeind=9&doccategoryind=0&operatingsystemind=121210&validate=true
Here are specific links for what you need:
Audio:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/thinkcentre_drivers/q2aud02us13.exe
Ethernet:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/thinkcentre_drivers/q38z01us.exe
Video:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/thinkcentre_drivers/e7az65us.exe
or
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/thinkcentre_drivers/e49z86usa.exe
USB:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/thinkcentre_drivers/q1chp01us13.exe
Good luck with it, drivers are usually the biggest pain after a fresh install.
Moshe
1helpful
Missing ethernet driver, pci controllers, and some sm controller
I am not familiar with your computer but have you tried going to the control panel, then to device manager. Find the component, right click and then find drivers, click on update driver.
As for the controllers you would probably have to go to their website for updates after you fix the ethernet driver.
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
