Optoma EX615 DLP Projector Logo
Anonymous Posted on Aug 11, 2014
In my Optoma Projector EX-615, Power supply, the 7 Pin Chip is Burnt, U3, i need the part number for it, it is TOP 246 "or" LNK364..? pl send us the service manual "or" the parts list.
Need The Service manual Level 3 for the EX615, Optoma Projector.
color wheel light tunnel DMD chips retailer
Level 2:
  • Expert 138 Answers
  • Posted on Dec 18, 2014
Expert
Level 2:
Answers
138
Questions
Helped
94493
Points
190
No separately chip for selling,
you had better replace whole power supply, it will cost about USD89
5 Related Answers
Anonymous
  • 563 Answers
  • Posted on May 07, 2008
SOURCE: Optoma DV10 MovieTime Color Wheel replacement
Hi guys
Your best bet on getting your hands on a Service Manual would be to contact Optoma themself.
As for changing the colour wheel , it is pretty straight forward if you were able to open up the unit and get to it.
The colourwheel is mounted with three tiny scrws to a bracket in which it sits. And the bracket in it's turn is fastenend to the body of the Projector with two tiny screws.
First unscrew the bracket from the casing of the Projector and then take off the three screws that holds the Colour wheel to the bracket. Replace and do the whole proses again - but obviously just the other way round.
This is really easy to do yourself.
Give me a shout if you need any further assistance.
Thanks for using Fixya and good luck.
sonicmember
  • 4 Answers
  • Posted on Dec 03, 2008
SOURCE: Optoma EP Portable Projector - No Power
if the lamp asssembly isnt screwed in tight the unit will not power on. i did have a faulty lamp once, try fitting the old one back to check first. if not the power supply is faulty on the main board or a short in the supply to the lamp can cause this fault.
Anonymous
  • 14 Answers
  • Posted on Jan 16, 2010
SOURCE: orange light on lamp icon on Optoma EP732H Projector
This same thing happened to me, I removed the bulb and put it back in, it reset something and I was able to use the projector again.
Anonymous
  • Posted on Feb 07, 2010
SOURCE: The optics are dusty in an Optoma HD32 projector,
go to http://www.tantht.blogspot.com/ . He has excellent instructions for dismantling an optoma projector. However I took it one step further. I still had a problem with overheating due to dust after I followed his steps twice. Then I also removed the back of the projector which gave me much better access to an internal fan. I could see a substancial amount of dust coming out when I blew compressed air through it this third time around. It has been working fine for 6 months since.
Testimonial: "Thanks, was exactly what I was looking for. "
Anonymous
  • Posted on Jan 06, 2011
SOURCE: my optoma hd80 has a blochy color problem i found
With projector on, hit the power button on the remote once, then left, left, up.
Optoma EP781
if all lamp are red, and no light on, It is power supply issue,
you need to replace power supply, it will be ok.
you can send me your old power supply photos, perhaps i have same parts,
Picture is snowy on most the picture. Cannot see picture because of the white snow.
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.I supply the DMD chip and the price is USD200
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
1helpful
2answers
My optoma projector has a green tint
it may just need a service, as all DLP projectors need to be cleaned internally as well as LCD.
DLP projector images will flicker and lose colour also may shut down if it is very dusty inside.
1helpful
Hi, I have a projector Optoma EP7155 and it appear white and black spot like dead pixel, I would like to know where I can buy a DMD chip with the CCD and how much it will cost. Thank you
global projectors is one source. You need to find out from Optoma the chip you need or take apart the machine and look at it. From China they run about 200 bucks. I've only done Mitsubishi so far.
32helpful
7answers
My optoma is projecting white spots onto the screen. They seem to just appear. Some have began by 'sparkling' for a while and then they stay white perminantly.
if it is a DLP projector then the DMD on the engine is likely bad or the main board is bad. The white things are pixels.
Optoma Projector power LED is blinking green,funs are not working, lamp not function, how can i solve this problem
i'd say power supply issue, but the led is blinking green. this means that it thinks it's in warmup/standby mode. but if nothing's running, the main board might be bad and needs to be replaced.
5helpful
Microtek cx6
I've had the same problem with my projector three times (usually whenever there's a sports championship). You just need to call optoma, get an RMA number, and ship it to them. Theoretically they'll fix it under warranty and send it back free.
Top Optoma Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
