Samsung Pl70 Silver Logo
a
alan Posted on Aug 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Charge led on pl70 usb charge lead won't illuminate at all
The triangular red/green led on my pl70 usb charge lead will not illuminate so I can't charge my camera
Pat McCabe
Level 2:
New Friend:
  • Expert 52 Answers
  • Posted on Aug 11, 2014
Pat McCabe
Expert
Level 2:
New Friend:
Answers
52
Questions
Helped
8888
Points
122
Most likely the actual charger unit has failed and is not supplying power to the cable or LED, therefore no charging will be possible. Buy a new charger unit.
Why does my Litezall 1300 rechargeable headlamp flash red, then green, then red, then green, while I'm charging it?
Question edited for all the typos.
It is charging the white and red LEDs. When fully charged it will be green. Or it is at that point where it is almost charged and can't make up its mind!
Charging:
This product is rechargeable. Please charge fully before first use to ensure optimal performance. Plug the full sized USB plug of the included charging cable into any USB power source such as a power cube, computer or car charger. Open the charging port cover at the bottom of the battery pack and insert the micro USB plug. The charging indicator on the back of the battery pack glows red while charging and changes to green when fully charged. Remove the charging cable and replace the charging port cover.
https://www.google.com/search?q=litezall+1300
AKG K 830 BT
My akg show always green lite but it not charge
Emission warnig light on
Check Engine Light
The fault codes are cleared after the problem has been rectified and the engine has been started 5-10 times.
Service Interval Reminder Lights
The on-board computer is used to evaluate mileage, average engine speed and engine and coolant temperatures as well as other computer input factors that determine maintenance intervals. There are 5 green, a yellow and a red LED used to remind the driver of oil changes and other maintenance services.
The green LED'S will be illuminated when the ignition is in the ON position and the engine OFF. There will not be as many green LED'S illuminated when the maintenance time gets closer. A yellow LED that is illuminated when the engine is running, will indicate maintenance is now due. The red LED will be illuminated when the service interval has been exceeded by approximately 1000 miles. This is the computers way of saying this is your last warning.
There is a service interval reset tool manufactured by the Assenmacher Tool Company (tool 62-1-100). This tool is used to reset BMW 6-cylinder and 4-cylinder vehicles with the aid of an additional adapter tool.
  1. Locate the diagnostic connector near the thermostat housing.
  2. Plug the special reset tool into the diagnostic connector and place the ignition switch in the ON position.
  3. Depress the reset button on the tool until all 5 green LED'S are illuminated, showing that the reset has completed.
21helpful
Any idea how long it takes to charge the Sylvania SMP2012? How do you tell when it is fully charged?
The Sylvania SMP2012 charges fully in under 15 minutes on a regular USB port. Sometimes it's much quicker.
When the device is charging, both the red and green LEDs are lit (not flashing). When the device is fully charged, the green LED turns off, and only the red LED is on.
4helpful
Silver Sylvania smp2012 2gb what kind of charger do I need for this mp3 player
No separate charger is required. Use a USB cable to connect it to any computer (desktop or portable), or to any powered USB hub. It should charge in about 5-20 minutes. While charging, both the red and green LEDs are lit. When fully charged, the green LED turns off and only the red LED is on.
This device should also be possible to charge using a stand-alone USB power source, such as those used to charge Blackberries.
10helpful
How do you charge the samsung SL202 camera
You charge the rechargable battery in the camera by turning the camera off and connecting to a USB port on your PC (not a USB hub). If the red LED is on the battery is being charged. If the green LED is on the charge is complete. If the red LED is flashing there is an error and you should check the seating of the battery. The USB port must provide 5V and 500mA for a complete charge. the manual for your camera is at http://downloadcenter.samsung.com/content/UM/200909/20090930164417500/SL202_English.pdf
3answers
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
