How do I get the water hose off the pressure washer ?
Hello Morris Daniels - Are the house valves fully turn on? Is the hose kinked or pinched? If not, then it sounds like you have an issue with the water pressure and possibly will need to replace the pressure switch. First try checking water pressure at another faucet in the house. Wait until water supply and pressure increase (water pressure for washer must be at a minimum of 30 psi). Straighten the water inlet hose if it is twisted or kinked. If any proves to be ineffective, contact a professional to move forward accurately.
Hi
If the washer won't fill you'll need to check for the water
inlet hose, the water inlet valve and the pressure/water level switch assembly.
Inspect the inlet hose coming to the washer for any blockages. If the hose is
not clogged then check the water inlet valve for any clogs, if the water will
not even fill for few seconds then certainly the water inlet valve is bad and
should be replaced. You can also use a multimeter to check continuity on inlet
valve. If you don't get any value on the multimeter then you'll need to replace
the water inlet valve assembly. However, if the valve is fine then the
pressure/water level switch assembly should be replaced. Hope this helps...
Please post back if you need more information.
Daniel
Hi
Daniel
