I need help with setting up the unit, register it, set time and date
SOURCE: time and date
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
SOURCE: How do I set the date and time on my Panasonic Lumix LZ2 Digital Camera
Hi there.
You will find time and date in the settings menu on the camera.
Good luck and thanks for using FixYa!!
SOURCE: Panasonic kx-t7731 phone.... How do you set the
While the hanset is on the cradle press # or * until the desired display is shown. If that does not work press the info key below that is shown on the screen.
SOURCE: how do i set the date on my panasonic kx-t7730
With the handset on the cradle press Program * # followed by the system
password ( default is 1234). Now press 000 and then Sp-Phone.Enter the
year and then scroll to the month with the right scroll key (located at
the right bottom corner of the phone). To change the month use the AUTO
ANS / MUTE button. Now scroll right again and change the date and day.
To change the day again use the AUTO ANS / MUTE button. Now scroll
right again and the time will appear. Set the time. To change am/pm
scroll to it and again use the AUTO ANS / MUTE button. Press program to
exit program mode and your done.
Please rate this answer if it was helpfull
Thank you
