Weed Eater Featherlite Fl20 Lawn Edgers Logo
A
Anonymous Posted on Aug 11, 2014
Why does my fl-20 need the choke to run? - Weed Eater Featherlite Fl20 Lawn Edgers
Jim flowers
Level 3:
  • Master 1,098 Answers
  • Posted on May 05, 2016
Jim flowers
Master
Level 3:
Answers
1098
Questions
Helped
359000
Points
2966
The carburetor is clogged. it needs to be cleaned. if it will run on choke that means that it is starving for fuel but if it runs at all it is an easy fix. just take the carburetor apart and clean with carburetor cleaner good and it will run like new. good luck
1helpful
2answers
WeedEater FL 1500
if the choke needs to stay on to run it then there is a plugged jet in the carb
I have a weedeater feather fl 20 it only runs on full choke, but when i try half choke or run it dies out.
Check the carb or idle adjustment screws on the side. Sounds like you're not getting enough air.
Mar 01, 2011 • Garden
1helpful
Weed eater FL 20 starts but has to be choked all the time and when spedded up it kills'
I'd guess that you have a bad diaphram in the carb and will need to rebuild it. The diaphram pumps the fuel and if it stretched or torn this is what will happen
2helpful
3answers
I have a 2004 Yamaha Vstar 1100 that stalls when I take the choke completely off. It will run on 1/3 choke, but back fires terribly. I have replaced both spark plugs, the battery and put a fuel additive in...
Dawn it is running lean if it will run on 1/3 choke when you choke it like that it actually restricts the air flow into the carburetor my suggestion would be to remove the carburetor and clean it real good and try that first before going anywhere else
Connect an FL-20, FL-36, FL-40 or FL-50 external flash
The FL-20, FL-36, FL-40 or FL-50 external flash can be attached directly to the hot shoe on the camera. You also can use the FL-BK01 Flash Bracket and the FL-CB02 Hot Shoe to TTL cable.
Connect these external flashes...
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket - used to mount an external flash to the C-770 Zoom. FL-CB02 Hot Shoe to TTL Cable - this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Connect to external flashes
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket (item #200666) - used to mount an external flash to the C-770 Zoom. FL-CB02 Hot Shoe to TTL Cable (item #200663)- this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Connect a FL-20, FL-36, FL-40 or FL-50 dedicated external flash
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket - used to mount an external flash to the C-750 Zoom. FL-CB02 Hot Shoe to TTL Cable -this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket (item #200666) - used to mount an external flash to the C-5060 Wide Zoom. FL-CB02 Hot Shoe to TTL Cable (item #200663)- this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
2answers
External Flash
Yes, the FL-20 Flash and the FL-36 Flash are both available accessory flashes that cover a wide variety of lighting needs. The FL-50 is designed for advanced to professional photograhphers who need the greatest light output.
Top Weed Eater Garden Experts
Jay Finke
Jay Finke
john h
Are you a Weed Eater Garden Expert? Answer questions, earn points and help others
