Interior light comes on
Be very careful around microwaves they have very high voltage inside them that can be deadly. As for the control panel its very common for grease and oil to get behind the plastic film of the control panel, once it does the buttons will stop working since the grease insulates the contacts. Unplug it from the power, let it sit for 60 minutes to make sure all power from the high voltage caps has dissipated. Get access to the back of the control panel. You will probably have to peel back the control plastic on the front to get behind it. One behind clean all the buttons and contact areas. Reassemble, and it should work.
