Breakers are not fast-acting.
Generally they will let heat on the wire build up slowly that can slightly exceed the actual 60 amp rating.
But amp draw exceeding 60 amps cannot last long before it will trip... each event can be different with no exact answer available.
Also if the breaker is worn out or loose on the busbar, it can trip before amp rating is reached.
Use 6 gauge wire with 60 amp breaker
http://waterheatertimer.org/Color-codewire.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Main breaker tripping
replacing the main is a possibility and i saw someone suggestion to ck load on each leg of power , also a good idea but one thing i have also seen do this is a loose or corroded connection in the meter base or disconnect which causes a process called electrolysis that is a flaking away of the conductor itself in the meter base or disconnect feeding the panel main breaker and causing heat build up internal to breaker and making it trip but if you replace the main that is the time to check all these connection and it would not hurt to apply a little no lock or some other brand of oxidation inhibitor
