Question about Dell Inspiron 8600 Notebook
Usb ports loose and now wont work - Dell Inspiron 8600 Notebook
  • Dell Master
  • 2,404 Answers
If you have alot of usb ports that are loose then unsoldering and resoldering all those usb ports can take as much time as replacing the motherboard plus you'll know for sure with a new motherboard that the ports will work.
Sometimes unsoldering old usb ports and putting on new ones doesnt work cause loose usb ports can short out the motherboard.
Posted on Jul 05, 2009
  • 410 Answers
Even taking a laptop apart (to board level) is tough, but you need to order the USB socket on ebay and solder the new one in carefully. Are you a qualified miniature soldering expert?
Posted on Jun 30, 2009
6ya staff
SOURCE:
I use to just plug in my nikon coolpix L610 to my computer ,now it wont work.Whats going on?
hi,
did you try to plug it into another port than the defective one?
sometimes windows loose the control of one port and by changing it recognizes again on new port....
you may also have hardware drivers problems, take a look at the hardware properties to see if there is not a small yellow triangle on some hardware, it can be the source of the problem, search for updated drivers and restart.
or go to nikon's site, search for last driver for your model, and install it, this must solve the problem...
cheers,
mich
Jan 21, 2015 | Nikon COOLPIX L610 16MP 3.0-inch LCD...
Will not come on was working fine before
If the USB port was fine, the unit would come on regardless if the battery was good or not. This is telling me your USB port is loose. We fix these all the time.
Most issues causing this is a bad charger, dead battery or caused by a loose USB port in the back. If the port is loose, the battery will not be charged and won't even work when connected to an external charger. More info can be found here:
http://www.sharc.net/gps_charger_repair.htm
Sep 27, 2013 | Garmin nuvi 1350 Car GPS Receiver
The charging port is not working on my zeepad 7.0
both of my charging ports on my zeepad are TOO LOOSE and wont make contact anymore, i need both ports so i can repair it myself, im so disapointed in the quality of the charging ports, one is a usb aanother is a skinny pin type...I really need the ports from someplace..
Aug 09, 2013 | ZEEPAD 7 inch Android 2.2 Tablet
My blackberry bold wont charge no light comes on just completely dead could it be a faulty battery
Does the red light come one when you plug it into a charger? if not, and your charger works on other phones, than you probably have a broken usb port. (check if it is loose). You're gonna have to disassemble the phone and repair the USB port : Blackberry Repair Guide.
Jun 29, 2010 | RIM BlackBerry Pearl 8100
The mouse works but when we type on the keyboard, nothing happens
Hi. Well you didn tell what kind of keyboard are you using. Is it a USB or a wireless. I am assuming that it is a USB keyboard.
  1. 1st of all check whether the key board is properly plugged in2 your machine properly, check for loose connections.
  2. Check whether you have plugged it into the correct port,because usually the the internet keyboard do not adapt to the USB port, and a PS/2 to US adapter port wont work.
  3. Download and install the latest Keyboard Software
  4. Before installing the new driver dont forget to uninstall the previous one, install the new one and reboot.
Nov 26, 2009 | Computers & Internet
The USB port on the NUVI 260 is loose and will not charge
You will not be able to refasten it yourself. This is a surface mount part and you need a very small tip soldering iron to fix it, plus you ned to know how to modify it so it wont break again. Please see this link:
- Jim
Oct 19, 2009 | Garmin GPS
The usb port is loose. that is why it wont work
If it in Worranty Period, Contact Service Center of Logitech.(Recomanded)
Oct 06, 2009 | Logitech ClearChat Pro USB Headset
Wont connect to wireless network
first, I suggest trying a different USB port. remove the adapter and the icon should disappear, so if the usb port is loose or broken that may be why its acting like that. Plug it into a different port and try it. You may have to reinstall the driver for the next usb port depending on your system
Aug 27, 2007 | Linksys WUSB300N Wireless Adapter
Dell Inspiron 8600 Notebook Logo
346 people viewed this question
Ekse
Clive
Clive
Alun Cox
