SOURCE: wiring 4 wird dryer plug to 3 wire 10/3 for 220 welder
the four wire plug seperates the neutral and ground. the three wire just piggybacks the ground to the neutral. so just get a three wire cord that fits the 220 plug on the generator and install it on your dryer make sure to attach the ground correctly for your three wire setup
SOURCE: How to install capacitor to
if the cap has two terminals it doesnt matter where you put the wires
SOURCE: Kenmore Dryer model 86683100. I need to change
Yeah, red and black go to the outside terminals, white in the center and green goes to the cabinet. What I do is hook up the red, white and black, then I place the green between the terminal block cover and the frame and screw it in tight.
SG
SOURCE: need wiring instructions to install a 4 prong wire from a 3 prong wire
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
go to this link and you will have your solution
